Fanuc Robot Stuck "Busy"
  • Dan Turner
  • December 15, 2024 at 3:40 PM
  • Dan Turner
    Hello, I am having a strange issue on a R30iB Plus V9.4 Controller. The controller sporadically gets stuck busy and running, it seems to always be on a motion instruction, it gets to the line in the program and then freezes for an amount of time without moving and then suddenly springs to life.
    I can press HOLD, turn on the teach pendant, even E-Stop the system and the Run and Busy indicators stay illuminated for an amount of time. The teach pendant is not frozen, I can still navigate perfectly fine.
    I have seen the issue both on Roboguide and on the physical system but can't find a pattern of what is causing it or reliable recreate the issue. I have two Ethernet IP connections, a Profinet connection, Proface HMI connection via SNPX and a few BG Logic programs.
    Ethernet IP are both only 2 words IN/OUT, Profinet is 16 Words IN/OUT, SNPX Assignments are 10 string registers, details of 5 current alarms and 200 registers.
    Any ideas would be appreciated :smiling_face:
  • Nation December 15, 2024 at 6:23 PM
    Approved the thread.
  • DylanNOEL
    18
    87
    • December 16, 2024 at 5:27 PM
    Do you have any karel program or any program that start automaticaly ?
    Please don't let me google it for you :winking_face:
  • EnergyAddict
    45
    133
    • December 16, 2024 at 7:07 PM
    Is your Program setup in a loop that it always returns to that motion instruction at the top? (See my example below):
    :  !Main Loop ;
    :  LBL[1] ;
    :  !Start at Perch ;
    :J PR[1:Perch] 75% FINE    ;
    :  IF (Logic is Satisfied) THEN ;
    :  DO SOMETHING ;
    :  ENDIF ;
    :  !Finish Cycle ;
    :  JMP LBL[1] ;
    :  END ;
    I've seen code similar to this where, the If logic isn't satisfied, and the busy lamp acts as you're describing. Simple solution was to throw a small wait statement after LBL[1].
  • Dan Turner
    • December 18, 2024 at 11:06 AM
    I have BG Logic programs but no Karel programs and no simultaneous programs.
    I do have a main loop but there are no motion instructions in the loop itself, the loop checks load/unload conditions of different stations in the system then calls the required load/unload program.
    I don't know if this helps but as far as I can tell, the issue doesn't happen if the program has been stopped
  • Dan Turner
    • December 18, 2024 at 12:42 PM
    Just noticed I didn't fully answer the first response, therr is no automatic program starting/stopping, there is one main loop that runs constantly
  • Dan Turner
    • December 18, 2024 at 1:43 PM
    Update: It seems that adding the wait to the start of the loop has fixed the issue, I had previously tried adding a wait just before the motion instructions that it gets stuck on but that didn't help so I nearly dismissed your suggestion xD
    I guess the controller gets bogged down running though the main loop so quickly when all conditions are false.
    Thank you!
  • HawkME
    568
    3,268
    • December 19, 2024 at 4:24 AM
    There is really no reason to have a continuous running TP program on a robot. That isn't how they are intended to run and makes troubleshooting difficult. Use a wait instruction to wait on a start signal. The start signal can come from a PLC or the robots own BG Logic.
  • hermann
    406
    2,607
    • December 19, 2024 at 5:52 AM
    Quote from HawkME
    Almost every main program on every robot I have written in the last 35 years is a continuous running one, after it has been started by a plc or background process, and until it has been stopped by PLC/BG process or safety devices.
    So I am doing it wrong all my programmers life:bawling:.
    On Fanuc and ABB robots one have to have a short wait instruction in a loop with only logic instructions without movements but Kuka Bots don't care about endless loops without wait instruction. Must have something to do with task scheduler of OS.
  • HawkME
    568
    3,268
    • December 22, 2024 at 7:03 PM
    Depends on what we are talking about by continuous running loop. If the robot is continuously moving and doing stuff, that's great. I just don't like having a continuous running loop to check for a start signal. A Wait instruction that waits on the signal instead of time achieves the same thing and you can see which line of code it is waiting on instead of a constant blur.
