  4. General Robotics Discussions - everything but NO Industrial Robots
Line follower robot
  • Jawad_ayoub
  • December 13, 2024 at 3:18 PM
  • Jawad_ayoub
    Hi every one ,
    I have a line-following robot competition, and the path includes an intersection that the robot needs to pass. Can you help me or suggest an algorithm to handle this type of line? Also, how can the robot distinguish between an intersection and a stop box using Arduino?
    Thanks!
  • Lemster68 December 13, 2024 at 3:25 PM
    Approved the thread.
    Moved the thread from forum other Robots to forum General Robotics Discussions - everything but NO Industrial Robots.
  • zFery
    32
    • December 13, 2024 at 3:34 PM
    Hello, I’ve been using a bit of line tracking/following recently, if you could share some images or additional details,I’d be happy to assist, also is this for a simulator or a physical robot competition?
    SkyeFire
    1,039
    9,380
    • December 13, 2024 at 5:26 PM
    Depends a lot on the nature of the intersection, and what sensors you have to detect it. It's not hard to have a situation where a 4-way intersection is indistinguishable from a spot where the line simply gets wide.
  • Jawad_ayoub
    • December 14, 2024 at 6:22 PM
    Quote from zFery
    Hi ,
    Actually, this is a closed-loop path. I couldn’t find the exact shape of my specific path, but the stop box is a large black box where the robot needs to stop once it reaches it.
    And I am using a straight 5 ir sensors array with 2 N20 600 rpm motors.
    Images
      • 79.8 kB
      • 1,280 × 720
      • 8
  • Jawad_ayoub
    Quote from SkyeFire
    Hi , you can check my message about its specifications
  • zFery
    32
    • December 16, 2024 at 11:52 AM
    Quote from Jawad_ayoub
    Hi ,
    This is for a kind of line-following robot, I'm not very familiar with it, so I might be wrong in something.
    However, my brother already participated in a competition similar to this, but with a different type of robot and, I think, fewer sensors.
    The idea I remember he used, and which you could try, is arranging the sensors in an "X" pattern, then, when the three front sensors detect black and the two rear sensors detect white, the robot stops.
    Just a warning again, I'm not an expert in this, so I don't know if this will actually work, but it's an idea.
  • panic mode
    1,267
    13,033
    • December 20, 2024 at 9:15 PM
    if your robot reacts to DIFFERENCE between two sensors, the intersection will be irrelevant.and so will be short gaps in the line but in your case with five sensors, you would not are about gaps. yol would stop when none of the sensors sees the line.
  • Arduino
  • robots
  • PID line follower robot
