Using RI/RO without arm connector
  • gumpus
  • December 13, 2024 at 3:11 PM
  • gumpus
    8
    Hello I am working on M20ib/25 with R30iB+ controller.
    I would like to acess the pins of the RI*8, RO*2 on the EE interface on the J4 arm. FANUC A05B-1226-K004 is given as the reference for the connector but I am imagine the pins run back to the controller. It would be nicer and cheaper if we could wire into these I/O elsewhere without the custom connector. I did a little looking around in the controller, but didn't see clearly indicated where these pins are.
  • Lemster68 December 13, 2024 at 3:17 PM
    Approved the thread.
  • gpunkt
    124
    472
    • December 13, 2024 at 4:09 PM
    You can access them on the CRF8-connector on the 6-axis amplifier:
  • ASUA1
    24
    • December 13, 2024 at 5:18 PM
    The pins youre looking for are going to be part of the Robot connection cable. Youre better off not messing with that. If you're already in the controller why not just use the DO/DI?
  • gumpus
    8
    • January 6, 2025 at 2:12 PM
    the DI/DO come with additional purchases no?
  • ASUA1
    24
    • January 6, 2025 at 3:23 PM
    Quote from gumpus
    not true. you can use DI/DO without major purchase. Each Robot comes with a plug that can be used to wire DI/DO.
  • Nation
    Typical Robot Error
    538
    1,919
    • January 6, 2025 at 7:03 PM
    Quote from ASUA1
    Conditionally true. This only applies if you are purchasing a Mate controller. A normal controller (R30ib+) will not have IO besides the RI/RO for free.
