Anybus Communicator PROFINET IO-Device - EtherNet/IP adapter ABC4013-A
  • IlFincoITA
  • December 12, 2024 at 11:34 PM
  • IlFincoITA
    204
    I'm still looking for a solution to establish communication between a FANUC robot and a SIEMENS PLC. I’ve looked into the ANYBUS GATEWAYs, specifically the model ABC4013-A Anybus Communicator PROFINET IO-Device - EtherNet/IP adapter.
    I’d like to know if anyone has experience with this device, considering it’s not exactly inexpensive.
    What concerns me is that, while it’s straightforward to have a GSDML file for the PLC configuration, on the FANUC side the settings are very minimal. They are essentially limited to setting up the robot as an adapter, defining the number of bytes to exchange, and assigning it an IP address.
    On the robot side, only the Ethernet IP adapter option is available, not the scanner option. I had previously tried another device, the MOXA MGATE 5103, but it didn’t work because an Ethernet IP scanner was required on the Ethernet IP side.
    The key point is that when they refer to an Ethernet IP Adapter, they mean the gateway itself. So, clearly, a scanner, such as a PLC, must be connected to the gateway and vice versa... because there is also a version from the same brand with an Ethernet IP scanner, and I assume that in this case, an adapter would be connected to it.
  • gpunkt
    119
    456
    • December 13, 2024 at 11:06 AM
    I would propose one of two solutions:
    1. Equip the robot with Profinet, set it up as an I/O-device with the PLC as I/O-Controller.
    2. Equip the robot with Ethernet IP and use Siemens' own FBs for Ethernet IP communication (they have both EIP Scanner and EIP Adapter). See https://support.industry.siemens.com/cs/document/10…?dti=0&lc=en-DK
  • IlFincoITA
    204
    • December 13, 2024 at 11:12 AM
    Have you personally experimented with the SIEMENS Ethernet IP Scanner solution? I started there myself and encountered some issues... specifically the slowness of communication... although I didn’t have much time to delve deeper into it.
  • gpunkt
    119
    456
    • December 13, 2024 at 11:23 AM
    No, I haven't tried it myself, but I know of others who has done it with good outcome.
    In terms of communication speed, I have no info.
  • hermann
    404
    2,595
    • December 14, 2024 at 9:07 AM
    Have seen some posts here where they complained about ethernet/ip on Siemens plc.
    The ABC4013-A won't work for you it's Tha same as the MOXA, you need: ABC3313-A.
    Have used some of the HMS devices (not this specific one) and they work very good.
  • IlFincoITA
    204
    • December 14, 2024 at 9:44 AM
    Thanks hermann... just saw the ABC3313-A which acts as scanner to the Ethernet IP side.
  • HenrikSi
    • February 19, 2025 at 2:33 PM
    Hey!
    We are having the exact same situation that you described.
    Could you please provide an update how it ended up?
    Thanks a lot,
    Henrik
