Launch TP or Karel Program via HTML
  • Ranguet
  • December 11, 2024 at 11:50 AM
  • Ranguet
    Hello, I am pretty new to Fanuc and I am working on a project with a CRX Robot.
    My goal is to create an HTML app, with buttons to execute KRL or TP program. I have tried to use the Fanuc iPendant Controls but I am doing something wrong / I am not finding a solution to do this.
    I tried to use the Execution Control, to launch my Karel program, but it doesnt work, i have tried to use different path to the file but it doesnt work neither .
    My KRL program :
    PROGRAM premier
    BEGIN
    IF DOUT[2]=OFF THEN
    DOUT[2] = ON
    ELSE
    DOUT[2]=OFF
    ENDIF
    END premier
    My HTML :
    <HTML>
    <HEAD>
    <STYLE>
    p {color: black;background-color:#FFFFCC;}
    </STYLE>
    <title>Accueil</title>
    </HEAD>
    <BODY style="background-color:#FFFFCC;">
    <p><img src="logoa.gif" width="200"></p>
    <object classid="clsid:BEC06F36-B6DE-4903-838C-5B110F58550E" id="FRIPExecution1">
    <param name="width" value="32">
    <param name="height" value="32">
    <param name="FastLoad" value="1">
    <param name="Name" value="md/premier.pc">
    </object>
    </BODY>
    </HTML>
    Thanks for your help, if you have any working example or others solutions I am taking it.
  • massula December 11, 2024 at 1:11 PM
    Approved the thread.
  • gpunkt
    138
    492
    • December 12, 2024 at 1:57 PM
    Get in touch with your local rep and ask for the plugin developer kit.
    For Tablets, iPendant Controls is not very good. Instead, you're better off with developing your HMI as a plugin.
  • hermann
    412
    2,624
    • December 13, 2024 at 5:47 AM
    Do you use it on TP or on an external device like laptop or tablet? Those controls only work on TP.
  • Ranguet
    • December 13, 2024 at 1:56 PM
    Thank you for your answer.
    I am using the Tablet teach pendant.
    I found a way to do it, using flag, macro and background logic. But it should be more simple if i can simply launch TP program using a HTML button from the iPendant Controls.
  • hermann
    412
    2,624
    • December 13, 2024 at 2:43 PM
    Have no experience with custom HMI on Tablet pendant. But as it is a Samsung Tablet, may be the custom controls don't work there, just like on external tablets.
    For html pages on external tablets there are examples in documentation: "iPendant_Screen_Customization_Function"
  • NeySEA
    31
    • December 28, 2024 at 6:41 PM
    We do it now. I believe you simply want to use other style starting method and in your Karel routines logic just use call program and it will call whatever tp program you have named provided it’s in the same directory of the compiled karel . pc program. We used to use a number field next to the tp program names we wanted to call but since have modified the Karel program with a variable so all it looks for now is the named TP program your Karel program wants to have execute. You must have end statements at the last line of your TP programs for your Karel routine to move to the next Karel routine in your logic . I can check more specifics for you if you need but we have this same Karel program setup using the TP with an html HMI page that controls the whole system . Basically you need to just use other start method on the controller use the html HMI on the TP browser to start the Karel program and subsequent calls to any TP program you have on that Karel routine/routines
  • Ranguet
    • January 9, 2025 at 10:40 AM
    Thank you, I'll test it.
  • tp
  • html
