Measuring precise position of a part without touch sensor.
  • darth0
  • December 5, 2024 at 2:55 PM
  • darth0
    138
    Grettings !
    We have a problem with a production of one type of parts. We cannot guarantee repeatability of produced part and problems occour when the parts need to be Arc welded with robots - The seam doesnt always come in the programmed position.
    The company wants to avoid investing in laser sensors becouse of related problems with reflection, they were thinking about getting a camera for robot vision.
    I was thinking, is there any possibility of solving this problem with a program for measuring where the Seam is.
    With the help of $PX50 - Torque Values, the robot would touch the position where the seam is and if it measures that the seam isnt in the " correct " location, it would then call a shifted program.
    is something like this possible with the use of Torque values of axis or do we need to invest into either an optical sensor or camera ?
    Ty for all help and suggestions im still learning stuff !
  • jarm
    247
    • December 5, 2024 at 3:23 PM
    or touch sense with the mig wire...that's probably a little cheaper then a camera or laser. You'll have to price it though but it's another option. Using torque values to locate a seam isn't anything i've seen before. Wouldn't be my go to.
  • roboprof
    24
    464
    • December 5, 2024 at 5:24 PM
    Here are some of your options:
    - touch sensing with welding wire (probably cheapest option)
    - Accufast laser sensor (reflectivity may be an issue)
    - Servo Robot ICube - not sure about reflectivity - or pricing
    Touch sensing may be your best option.
  • 95devils
    230
    8
    1,936
    • December 5, 2024 at 6:12 PM
    Problem I see, is your touching a part with a thin wire. The weld wire will bend before the robot even knows it. The torque isn’t going to change.
  • jarm
    247
    • December 5, 2024 at 6:25 PM
    I wouldn't trust using the cup either, i'd be afraid of bending my gooseneck
  • TSGIR
    81
    713
    • December 5, 2024 at 10:22 PM
    You said about reflection in the part if you use laser, what is the material?
    Laser can use for all type of material, i use in the aluminum that have more reflection and it work without any problem.
  • darth0
    138
    • December 6, 2024 at 7:10 AM
    Thank you for all your information.
    My initial plan was as someone mentioned to do Touch sensing by using the weld wire.
    The problem with this is, as someone also mentioned, the wire bends easly and im not sure that the axis would register any proper torque change before the wire bends. i guess i would have to test that somehow.
    Another idea would be using the gooseneck of the welder but the problem with that is if it bends from too much force it needs to be changed - expenses.
    As far as i know ( ive been at this position for 2 month now) the problem is becouse we work with cold rolled steel which has high reflectivity. I mentioned a possible solution would be getting laser sensor for locating seams ( it could probably also be used for getting exact position of the working part), but Bossman said the reflectivity would be a problem and that he would rather buy a camera - but isnt sure himself the cost vs benifit would be worth it for us.
    That is why im trying to find an alternative to using expensive sensors.
  • hermann
    405
    2,596
    • December 7, 2024 at 9:31 AM
    Quote from darth0
    .. cold rolled steel which has high reflectivity.
    Quote from darth0
    .. that he would rather buy a camera -
    cameras often also have big problems with high reflective material.:frowning_face:
  • Robodoc
    56
    7
    1,059
    • December 7, 2024 at 2:27 PM
    If you are bending the wire doing touch sensing you need to slow the robot down.
    Robodoc
  • darth0
    138
    • December 9, 2024 at 6:57 AM
    Quote from Robodoc
    Do you have any specific speeds in mind?
  • jarm
    247
    • December 9, 2024 at 1:42 PM
    • #11
    You are not going to measure any torque using the wire no matter how slow the robot goes. Touch sense uses a voltage in the wire and detects the part when the wire grounds on the part. I think there is some confusion on what you were planning to do. Touch sense is pretty reliable. We have it on all our robots. Yaskawa, ABB doing exactly what you want your robot to do..price it out. It will save you headaches for sure.
    Our last robot came with touch thru the wire and a little spot laser. I only use the spot laser. I have had reflective issues a few times but that was mostly from measuring at too much angle to the part. If you measure directly adjacent, i've never had an issue. It's a lot faster than using the wire too. Everything we weld is mild steel btw
    Edited 3 times, last by jarm (December 9, 2024 at 2:12 PM).
  • darth0
    138
    • December 9, 2024 at 2:55 PM
    • #12
    Quote from jarm
    Cheers for the detailed answer!
    Yes it seems i didnt quite get out what I wanted to do, hence some people thought we have a touch sensor ( we do not).
    Im going to do some research then with prices of touch sensors and laser sensors. I assume touch sense can be usefull in practically any application, where as Laser sensors would have a problem with high reflectivity, but even that can be managed with angles.
    Do/did you have any problems with metal dust covering the laser ( causing interferance) - requiring extra cleaning etc?
    Thank you for sharing your knowledge, really appreciate it !
  • jarm
    247
    • December 9, 2024 at 3:08 PM
    • #13
    no, the spot laser has a door that opens every time it goes to make a measurement
  • YakawFaBB
    68
    • December 16, 2024 at 11:27 AM
    • #14
    Quote from darth0
    Hi darth0 ,
    I use often the touch sensor on aluminum and steel, it's works perfectly on dust covering.
    As long as the electrical contact works the touch wire sensor works.
  • darth0
    138
    • December 16, 2024 at 12:49 PM
    • #15
    Quote from YakawFaBB
    Hi darth0 ,
    YakawFaBB Hey cheers for the answer !
    I looked a bit into touch sensors and that seems like the perfect solution for us, as they can be used in the wides variety of applications and speed/cycle time isnt an important factor for us, where a laser/camera sensor would make more sense.
  • measurement
