KRC4 Active Project: Old Programs Persist After New Project Activation
  • ohm_625
  • December 5, 2024 at 10:29 AM
  • ohm_625
    13
    Hello everyone,
    I'm currently working with OfficeLite KSS8.7.6.
    I just finished a project and would like to start a new one from a fresh base.
    I took the base project, renamed it in WoV, added a couple of functions, and reloaded it back into OfficeLite.
    However, I noticed that folders from my old project (which don't exist in the new project) are still present after deploying and activating the new project.
    Did I miss an option somewhere? How can I ensure that my active project on the controller contains only the files related to the deployed WoV project? Do I need to manually delete residual files ?
    I've to be honest, I've never encountered this in the field because each controller was always dedicated to a single application.
    Thanks in advance!
  • panic mode
    1,296
    13,136
    • December 5, 2024 at 3:01 PM
    • Best Answer
    unfortunately, for some messed up reason, WoV does not remove existing files and folders in KRC:\R1\...
    you will need to delete the files/folders manually...
    unless there is some setting I looked for but did not find yet...
  • ohm_625 December 5, 2024 at 3:11 PM
    Selected a post as the best answer.
  • ohm_625
    13
    • December 5, 2024 at 3:11 PM
    Thank you, I set the topic as resolved.
  • #kRC4
  • #WorkVisual
