Having a problem with are Panasonic robot that hasn't ran in a while. Robot has A and B side. Table was Programmed at zero, but now table moves 90 degrees when running the program. I guessing the origin is off. Not sure how to change the origin.
Panasonic Robot origin
sbecker -
December 2, 2024 at 4:59 PM -
When you last time use calibration? Maybe someone did it? 100% sure calibration "zero pos" would help, but before check the reason, some of connects can be broken or something else
My bad, it's not fanuc but stilll can help
You can set "standard position" 90° or -90° and everything will move. 90 you will se as 0. It is on set management settings system external Axis more or something like that and "standard position"
Or someone make wrong calibration. But if You sure that is exactly 90° make it by standard position.
