How do you generate the XHBK Signal?
  • HansAlbrecht
  • December 2, 2024 at 12:27 PM
    HansAlbrecht
    hi!
    The endeffector plug provides the possibility to integrate a hand broken signal via the XHBK input on pin 7.
    What would be a smart way to generate this signal? I cannot think of how to get an electrical signal to reliably drop on mechanical failure.
    To me it seems more practial to hook this up to permanent 24V and rely on collision detection.
    best regards,
    Hans
  • Nation December 2, 2024 at 12:32 PM
    Approved the thread.
  • Nation
    Typical Robot Error
    522
    1,900
    • December 2, 2024 at 3:12 PM
    • Best Answer
    Typically you wire that signal up to a collision sensor, such as one of these.
    In general though, it is more of a relic of the past, back when software collision detection wasn't very good. Although, I have seen these on modern MIG welding cells, where the torch can get bent easily.
    If you aren't going to use it, you can just disable the signal in the SYSTEM->CONFIG menu. It is controlled under the "Hand Broken" item. You don't have to wire it.
  • gpunkt
    119
    456
    • December 2, 2024 at 3:58 PM
    I think that this is used with ARC-welding guns, and a magnetic coupler that, when collision occurs such that the gun is dislodged, the circuit through this magnetic coupler is broken and then the stopping alarm is issued.
  • HansAlbrecht December 2, 2024 at 4:12 PM
    Selected a post as the best answer.
    HansAlbrecht
    • December 2, 2024 at 4:13 PM
    alright, then I won't use this at all in pick&place applications.
    Thanks for the replies!
