Rj-2 Checksum 80846AA4
  • aroldino
  • November 26, 2024 at 10:44 AM
  • aroldino
    72
    A few days ago the robot began to write this checksum error on boot. We had to restart a few times to be able to get the robot run.
    And the robot has a huge lag from pushing a button on the TP and the move to happen, or resetting the errors.
    Now it looks that it doesn't want to start at all.
    Now we will change the batteries in the robot's base, but I read that there is a small battery in the main board too?
    Does the lag of the TP has to do with the batteries?
    Thanks,
    Arnold
    Images
      • 432.98 kB
      • 1,600 × 1,200
      • 13
    Edited once, last by aroldino (November 26, 2024 at 11:25 AM).
  • byrol
    13
    5
    347
    • November 29, 2024 at 2:11 PM
    Even if the batteries located at the base of the robot are not installed, it does not make the robot slow in software transitions. I don't think it's from the batteries in the base. In the picture, it also appears that the battery that should be installed on the CPU card is not in place, it must necessarily be installed and intact. There must be a software backup before starting the work that you will do with the CPU card. It may be that the software cannot make a healthy boot because it is corrupted, or there may be a problem with the rom memory in which it installs the software. But when you remove the rom memory on the CPU card, the software will be deleted, which is very important. A disconnect or short circuit in the control cable can also give this error, as well as there may be a problem with the control itself. It will be healthier to start with interchangeable hardware instead of trying to enter the CPU card. Even if it disconnects the cables from the servo floor to the CPU and gives an error, it can still be checked whether there is a slowdown in the software.
  • Skooter
    169
    2,028
    • November 29, 2024 at 4:04 PM
    The controller battery is located under a cover located on the front of the PSU B1 power supply.
    Most folks move the controller battery to the connection located at top of the Main Board and let it hang there. That way, battery voltage is still provided to the Main board if the power supply is removed.
    Battery part # is A98L-0031-0012.
  • aroldino
    72
    • November 29, 2024 at 6:39 PM
    Thank you for the replies.
    Unfortunately I don't have a software backup. So first I try to check every other method.
    The robot started to have communication lag between pushing a button on TP and the software to behave accordingly whule we were working on it. In AUTO mode the robot runs well, only when we need to make adjustments it had this lag. The temperature was not so high (~10 Celsius or little bit below). Than began with this Checksum error at booting. We had to restart it a few times and it worked. Now it doesn't want to work.
    There is a BUS fault LED lit on the I/O panel. Can this has have an impact on the error?
    I read in other posts that CMOS errors can be cleared, but I didn't found it the documentation. Could this error memory clearing help?
  • byrol
    13
    5
    347
    • December 2, 2024 at 11:32 AM
    Your Profibus card is installed in the I/O panel, that is, where you see it as an input and output card. The upper part of this card is the robot's manager and the slave is the place where the output is made to a card. The lower part is where the robot is a slave and the cable from the manager needs to be connected. The lighting of the red led does not cause your profibus card to work or your robot to have software delays. This is all about the configuration of the card. If you remove the configuration of the slave side of your card, the red led will turn off. If your Profibus card or servo drive card is defective, this may cause a slowdown in the software. We need to take out their connections and try. In the case of CMOS error cleaning, if the program that your robot is running is doing a lot, a lot of repetitions, and the program repeatedly calls another program in the loop and always stays ready by waiting for an external command, this may lead to RAM stacking after a while. In it, you can use the ram cleanup section in the FILE menu, but the program structure may need to be revised and shortened. If there is no software backup available, it may also be a solution to make a backup of programs and configurations and install a new INIT on the BMON screen. However, this job will restore your robot to the latest new software installation. The first software in FRAM may still be healthy.
  • Skooter
    169
    2,028
    • December 2, 2024 at 4:21 PM
    While the following ideas may not fix the issue, I've seen similar issues where this fixed the problem and they only take a few minutes to try:
    Try a cold start - keep the Fault Reset button held in while the controller boots up. You can also cold start from the Control Start menu.
    Do you have another R-J2 system? If so, 1- try another known good teach pendant & TP cable. 2- with the power on, move the battery from the power supply to the connector at the top of the CPU. Turn off power and try another power supply.
  • aroldino
    72
    • December 3, 2024 at 7:32 AM
    I tried to make a COLD START, but it didn't helped.
    Maybe there are 2 errors at the same time.
    I can't get the TP running, because of the CHECKSUM error. So I can't access any menu on the TP.
    Maybe the lag of the software is another problem.
    First I need to get the TP run.
  • aroldino
    72
    • December 11, 2024 at 10:18 AM
    Today finally arrived the new battery. I hoped that there is a battery problem, in spite that the Battery light is not turned on. But not.
    Nothing changed with the new battery.
    So I tried to make an INIT-START. I held down the PREV and NEXT buttons and start the controller. But the same screen appears.
    Can somebody help me how to start to investigate the problem?
    I have no idea how to start looking, and I didn't find any description regarding this kind of issue.
    The problem is with the main CPU, or the whole PSU circuit board? Or with the TP?
  • CHECKSUM ERROR
