RSI_SETPUBLICPAR gives invalid parameter ID
  • Zariwan
  • November 18, 2024 at 9:48 PM
  • Zariwan
    I try to set the amplitude from some RSI SOURCE Objects and send the signal over ethernet. I adapted the Ethernet Example for this. But the line
    ret=RSI_SETPUBLICPAR(CONTID,"SOURCE1","Amplitude", SIG1)
    and the 3 lines after that gives me a "Invalid Parameter ID" and i cant find any information on this and there are no matches for "parameter ID" in the forum elsewhere. The signal values are Dummys
    This is my full code. I am gratefull for any help.
    --------- Code ------------
    &ACCESS RVP
    &REL 4
    &PARAM TEMPLATE = C:\KRC\Roboter\Template\vorgabe
    &PARAM EDITMASK = *
    DEF RSI_AxisCorr( )
    ; Declaration of KRL variables
    DECL INT ret ; Return value for RSI commands
    DECL INT CONTID ; ContainerID
    DECL REAL SIG1, SIG2, SIG3, SIG4
    ;FOLD INI
    ;FOLD BASISTECH INI
    GLOBAL INTERRUPT DECL 3 WHEN $STOPMESS==TRUE DO IR_STOPM ( )
    INTERRUPT ON 3
    BAS (#INITMOV,0 )
    ;ENDFOLD (BASISTECH INI)
    ;FOLD USER INI
    ;Make your modifications here
    ;ENDFOLD (USER INI)
    ;ENDFOLD (INI)
    ; Prepare Values of for RSI communication
    SIG1 = 1
    SIG2 = 2
    SIG3 = 3
    SIG4 = 4
    ; Create RSI Context
    ret = RSI_CREATE("ros_rsi_slm.rsi",CONTID,TRUE)
    IF (ret <> RSIOK) THEN
    HALT
    ENDIF
    ; Modify Source parameter
    ret=RSI_SETPUBLICPAR(CONTID,"SOURCE2","Amplitude", SIG2)
    ret=RSI_SETPUBLICPAR(CONTID,"SOURCE3","Amplitude", SIG3)
    ret=RSI_SETPUBLICPAR(CONTID,"SOURCE4","Amplitude", SIG4)
    HALT
    ENDIF
    ; Start RSI execution
    ret = RSI_ON(#ABSOLUTE)
    HALT
    ENDIF
    ; Sensor guided movement
    RSI_MOVECORR()
    ; Turn off RSI
    ret = RSI_OFF()
    HALT
    ENDIF
    END
  • Lemster68 November 18, 2024 at 9:53 PM
    Approved the thread.
  • SkyeFire
    1,062
    9,465
    • November 21, 2024 at 12:17 AM
    Put code inside CODE tags for clarity.
    No mention of KSS or RSI version?
  • work_BR
    95
    • November 22, 2024 at 6:18 PM
    I've had problems with RSI SET_Publicpar in the past (and currently). I noticed when you set a bunch of them all at once it does not work as anticipated. I got around this Simply by putting wait sec 0.024 in between calls.
