Hello to everyone, I ask you for help because I haven't been able to find a solution to my problem.
I have a problem with a C80 controller during save operation.
I tried to do a backup using save command but i noticed a CPU error during save operation. Error is:
ERROR (-1100) CPU error (Code=00008008)
Task(MON1)Stop SIG=00008008 [FAULT(PARALLEL )] PC=30062724
I tried to do partial backup using save/ p,l,r,s,a etc.. and i noticed problem was in transformation points.
So I tried to load again transformation points, but I still have problem during transformation saving operation.
I don't have any other errors. It seems like some transformation value is corrupted.
Is it possible to do something as memory formatting, can be the right procedure?
Does anyone have any suggestions or has this happened before?
Thank you in advance for your help.
