Fanuc R30iA Ethernet/IP communication problem with NX-102-9020
  • MoonBeam
  • November 6, 2024 at 9:56 PM
  • MoonBeam
    7
    Hi !
    I just recently installed a new robot in production line (a M-410iB, with a R30iA cabinet), it's second hand but it has a lot of nice options like Ethernet/IP adapter and scanner.
    My problem is when i try to publish all the Tag Set from my NX (4bytes in and 4bytes out), TP is lagging, until it's completely frozen and just need a forced power cycle.
    Without Tag Set pushed, I can ping perfectly the robot.
    Robot is configured as Adapter.
    I verified all combination, my ethernet cable is good, IPs are matching, EDS is good too. It's like my robot cannot handle the exchanges of datas. Tried on port#1 and then port#2, did the same thing.
    I really wanted to use that option, if someone had ever see this case ?
    Thanks!
  • Nation
    Typical Robot Error
    556
    1,937
    • November 7, 2024 at 12:51 AM
    I'm not familiar with Omron, but I am assuming publishing tag set means establishing comms.
    Does Omron have a requested packet interval? Might be set too high.
  • MoonBeam
    7
    • November 7, 2024 at 6:04 PM
    Yes, it means establishing comms.
    Omron have a RPI, it is set at 32ms the default value. The only thing is missing is Configuration Instance. I tried to increase up to 1000ms same result.
    Something is clearly wrong in my config, or NX102 is defenitively not able to communicate properly with my robot.
  • pdl
    272
    1,549
    • November 7, 2024 at 9:09 PM
    Configuration instance should be 100 with a size of zero.
  • MoonBeam
    7
    • November 7, 2024 at 9:15 PM
    That's my big problem i dont have any option to configurate Configuration Instance and its size.
  • omron
  • R30-iA
