Fanuc CRX 10iA/L Ethernet TCP/IP Communiction with EOAT
  • volkesi
  • November 5, 2024 at 7:34 PM
  • volkesi
    Hello Forum!
    I am trying to set up the communication between a CRX robot and an EOAT tool using the Ethernet TCP/IP interface.
    I set up the Host Comm and got a connection but I don't know how to send/receive the parameters between the 2 devices.
    Example Robot -> EOAT
    <authentication>k
    <id> <set_f_target> <set_f_zero> <set_t_ramp> <set_payload> <reserve>k
    ferbak
    1040 100 0 0.5 9.9 0k
    Example EOAT -> Robot
    <authentication>k
    <id> <act_force> <act_position> <act_contact_state> <act_error_code>k
    ferbak
    205030401 0 0 0 0k
    How hard can it be?
  • Nation November 5, 2024 at 7:37 PM
    Approved the thread.
  • Nation
    Typical Robot Error
    529
    1,908
    • November 5, 2024 at 9:41 PM
    What is the EOAT tool? It might provide library or interface so you wouldn't have to roll your own comms.
  • volkesi
    • November 5, 2024 at 10:17 PM
    An Active Force Compliance - Ferrobotics ACF
  • PnsStarter
    90
    325
    • November 6, 2024 at 11:09 AM
    Hi volkesi,
    Ferrobotics provides a crx plugin, or?
    Have you installed it?
    If not or it is not available ask your Ferrobotics representive for karel files.
    If you have to build it yourself you have to check the api(documentation) and create your own karel (socket messaging ) program...
    best
    Backdate/TP-Tools: A small collection of tools that simplify the commissioning and programming of Fanuc robots. (github.com)
  • volkesi
    • November 6, 2024 at 7:30 PM
    I will look into that. Thank you for your replies!
  • ip
  • 10iA/L
  • 10ia
