KUKA KRC2 external HMI
  • Lzrf
  • October 31, 2024 at 6:31 PM
  • Lzrf
    8
    KUKA KRC2
    KSS 5.2.14
    Rob. KR200 comp3
    Hello to all readers!
    I want to connect the separate operator panel to the KUKA KRC2 robot
    What is the panel for? Use the panel to select SRC programs
    Is it possible to connect an additional HMI operator panel to the robot, if so, I have several questions:
    - Through which bus can you connect the HMI to the robot?
    - How and where to configure the robot files so that it can successfully communicate with the operator panel
    ( Select SRC programs and execute them )
  • panic mode October 31, 2024 at 8:58 PM
    Moved the thread from forum General Discussion of Industrial Robots Only to forum KUKA Robot Forum.
  • work_BR
    95
    • October 31, 2024 at 9:08 PM
    My gut answer is it is not possible to have 2 HMI's going at the same time. If you RDP onto the controller, it kicks out the pendant viewer and vice versa.
    Mirroring on the other hand might be possible? I'm not an expert at this.
    The more advanced way to do what you want is to use the C3 bridge.
  • Lzrf
    8
    • October 31, 2024 at 10:06 PM
    Quote from work_BR
    The C3 bridge is really interesting... but I don't know if it will be suitable for the task at hand.
    If I can't use 2 HMIs at the same time, that's not a problem. The main thing is to connect the second custom HMI.
    The main thing is that he can correctly communicate with the robot and run SRC files (that is, give a command to run a certain file)
    If I'm wrong, please correct me, because I'm just a beginner in this field :smiling_face:
  • work_BR
    95
    • October 31, 2024 at 10:21 PM
    So the Kuka is set up to ideally run Main.SRC.
    Kuka sells packages like DirectoryLoader so you can change What the contents of the file is from an external PC.
    If you never have to change the contence of the .SRC file you wana run, a traditional PLC connection is perfect.
    If you want to change programs from the PLC, you need a different approach.
  • work_BR
    95
    • October 31, 2024 at 10:23 PM
    I should say, If you only want to toggle between a handful of .SRC files, you can set up Main.SRC as a switch case, and toggle through what you want through some I/O.
  • Lzrf
    8
    • October 31, 2024 at 10:31 PM
    Quote from work_BR
    Yes, I completely agree with you. I have already considered the PLC as an SRC switch.
    Tell me how many programs can be switched using this method?
    It would be perfect if you could just choose the program and run it
    Approximately 50+ programs
  • work_BR
    95
    • November 1, 2024 at 3:07 PM
    I don't think there's a limit to the number of cases you can add. With over 50 however; it might get unruly to trouble shoot / change in the future.
    Kuka has a pretty good documentation on how to handle their PLC handshake. If you key word search the manuals for $EXT_START that's basically the value (among others) that will start the robots.
    I don't know how familiar you are with how the robots are supposed to function with a PLC, so i would say a good call would be to reach out to Kuka technical support. They're honestly great. They can help with manuals too.
  • Lzrf
    8
    • November 1, 2024 at 3:46 PM
    Quote from work_BR
    There may be some other methods of connecting the operator panel, for example through the port RJ48, RS232, RS485 or others. I found a YouTube video with what I need (link -
    But referring to this video, there they use EIP configuring KRC through workvisual, but in my case KSS 5.2.14 does not support WV.
    If you know how to setup EIP on KRC2 KSS 5.2.14 please advise
Similar Threads
  • KRC5 micro Serial Communication
    • ibrahim
    • May 31, 2024 at 8:01 AM
    • KUKA Robot Forum
  • Send a program number for the KUKA robot to execute from a Siemens PLC to a KRC2 with digital input and output modules using Interbus.
    • lino jelvez
    • February 15, 2024 at 3:00 PM
    • KUKA Robot Forum
  • HMI freeze for .src file copying on KUKA KRC2
    • mrashid36
    • February 28, 2023 at 8:33 PM
    • KUKA Robot Forum
  • Kuka KRC2 ed05 Click Status Bar to Get to Windows XP
    • RustyRSA
    • September 18, 2021 at 3:26 PM
    • KUKA Robot Forum
  • Kuka KRC 2 PTP_REL movement
    • RickPanic
    • November 20, 2020 at 7:29 AM
    • KUKA Robot Forum
  • [KUKA] LIN_REL problem
    • zwierzyk5
    • January 30, 2020 at 5:00 PM
    • KUKA Robot Forum
  • kss 5.2.14
  • KRC 2
