Geometric operator and Inv_Pos()
  • work_BR
  • October 31, 2024 at 5:59 PM
  • work_BR
    95
    I am a little stumped by the Inv_Pos() function Kuka has. I've looked around the forum and everywhere seems to point to old integrator manuals. I'm looking for peoples sentiment on this particular problem.
    I have a robot picking from a cart, and placing on a table. I want to have a program that can be ran once and get a vector that can be used to offsets subsequent place points. So you'd run a calibration program like:
    DEF CALIBRATION()
    IDEAL_POS.X = 1000
    IDEAL_POS.Y = 1000
    IDEAL_POS.Z = 1000
    IDEAL_POS.A = -90
    IDEAL_POS.B = 0
    IDEAL_POS.C = 180
    MsgDialog(DialogAnswer, "Adjust the robot "XTOUCHED_UP_POS", "Calib", , "Ok")
    HALT ; Jog to desired position and touch up the "XTOUCHED_UP_POS"
    ;INLINE FORMS DON'T WORK SUPER WELL SO TOUCH UP THIS POINT
    XTOUCHED_UP_POS
    NEW_CALIB_OFFSET = INV_POS(IDEAL_POS):XTOUCHED_UP_POS
    END
    Then the idea is at this point "NEW_CALIB_OFFSET" is the vector you seek that can be added in a different program like:
    DEF PROG_2()
    PLACE_PT = PLACE_PT:NEW_CALIB_OFFSET
    END
    So when you go to "PLACE_PT" it accounts for some of the inaccuracy in teaching the tool / base, some of the mechanical tooling slop and so on. This seems to work, but not quite. The values that pop out of "NEW_CALIB_OFFSET" are of magnitude <10 mm. The inaccuracy in my placement is about 2mm in X and Y.
    I don't understand how: NEW_CALIB_OFFSET = INV_POS(IDEAL_POS):XTOUCHED_UP_POS is different from NEW_CALIB_OFFSET = IDEAL_POS:XTOUCHED_UP_POS. One gives different values then the other obviously.
    I hope this ramble makes some sense. At a high level, what is the ideal use case of INV_POS()?
  • hermann
    412
    2,629
    • November 1, 2024 at 10:03 AM
    Quote from work_BR
    First is a subtraction of the two vectors, latter one is an addition of the two vectors.
    Quote from work_BR
    The highest level is: use it when you need it, otherwise don't use it. :icon_mrgreen:
    There's no ideal use case, it depends on what you want to calculate. Nobody can enumerate all use cases, there exist uncountable many use cases.
  • work_BR
    95
    • November 1, 2024 at 3:20 PM
    Quote from hermann
    First is a subtraction of the two vectors, latter one is an addition of the two vectors.s.
    Honestly thank you. This is exactly what i needed to hear.
    Quote from hermann
    Also lol
  • Hes
    42
    243
    • November 2, 2024 at 8:16 PM
    Inv pos is the reverse relation. Like your ideal_pos is a frame from base to the point. Inv_pos(ideal_pos) is the frame from the point to the base.
    Hence Inv_pos(ideal_pos):ideal_pos = $nullframe this is also true the other way around.
    Inv_pos i very powerful when trying to find the relation to something. Eg if you want to calculate the same point in another base or with another tool. Examples of this is available in the SI manual.
    There is a really good topic on this forum by MOM where alot of people pitched in. Cannot remember the topic but something along the lines of "geometric operator in depth" with really good examples and general discussion.
  • MOM
    176
    7
    1,424
    • November 2, 2024 at 8:28 PM
    Here is the topic Behind the scene - geometric operator
Similar Threads
  • Write protection on $OUT[48]
    • GregoryAshmore
    • May 3, 2013 at 9:13 PM
    • KUKA Robot Forum
  • Kuka.Sim 4.3 $ACT_POS_MES not working
    • sloopkogel
    • March 27, 2024 at 11:07 AM
    • KUKA Robot Forum
  • Behind the scene - geometric operator
    • MOM
    • April 15, 2023 at 1:03 AM
    • KUKA Robot Forum
  • frame transformation with interpolation change
    • mmilo31
    • January 23, 2023 at 5:28 PM
    • KUKA Robot Forum
  • Syntax of POS variables?
    • Rune_frost
    • April 14, 2023 at 9:30 AM
    • KUKA Robot Forum
  • How transformation is calculated when base is switched
    • kiwasuse
    • February 3, 2023 at 12:57 AM
    • KUKA Robot Forum
  • Calculating Coordinates in External Positioner Frame
    • dave tripp
    • October 25, 2021 at 4:41 PM
    • KUKA Robot Forum
