Good morning, I'm programming a KUKA kr 470-2 PA e¡with KR C5 and KSS 8.7.6.
I see stops between points when I trigger some programs. I use trigger when distance = 1 or when path = -200 depending on ptp or lin.
The programs have no INIT. If I activate a signal or have waits I have a Continue on the previous line. I tried to set the conditions of the waits to true with the plc before evaluating them. $APO.CDIS=200 $ADVANCE=3. I activated $STOPNOAPROX to true in automatic and I don't see any change in the flow nor messages.
Few experience programming Kuka but research done, so any advice will be well received. Thanks.
