Interrupt, I set $PRO_ACT=FALSE
  • Jozef Karas
  • October 30, 2024 at 4:15 PM
  • Jozef Karas
    14
    Hello, how do I set the interrupt, I set $PRO_ACT=FALSE?
  • SkyeFire
    1,044
    9,391
    • October 30, 2024 at 6:13 PM
    Quote from Jozef Karas
    $PRO_ACT is a system variable that shows the run status of the program interpreter. You cannot control it.
    "How do I set the interrupt" is too vague to make any response to, beyond "read the manual."
  • work_BR
    95
    • October 30, 2024 at 10:21 PM
    INTERRUPT DECL 126 WHEN $CYCFLAG[126] DO Your_program()
    $CYCFLAG[126] = NOT Your_variable
    INTERRUPT ON 126
    When you declare a program, where you put your "DECL INT BLAH1, BLAH2..." declare your interrupt.
    It's kind of annoying that the value has to go from false to true (rising edge), but using the $CYCLEFLAG structure above i found is an easy way to get what you want.
    If you use the $CYCLEFLAG style, in the "Your_Program()" you need to turn the interrupt off, do what you want to happen, then turn it back on again with the:
       INTERRUPT OFF 126
       ..code..
       INTERRUPT ON 126
  • Jozef Karas
    14
    • October 31, 2024 at 8:22 AM
    GLOBAL INTERRUPT DECL 2 WHEN bIR_HALT==TRUE DO IR_HALT()
    INTERRUPT ON 3
    GLOBAL DEF IR_HALT()
    INTERRUPT OFF 2
    bIR_HALT=FALSE
    BRAKE
    WAIT SEC 0.8
    HALT
    INTERRUPT ON 2
    END
  • work_BR
    95
    • October 31, 2024 at 3:29 PM
    ;INTERRUPT ON 3
    --Your robot code--
    END
    ;INTERRUPT OFF 2
    bIR_HALT=FALSE
    BRAKE
    WAIT SEC 0.8
    HALT
    ;INTERRUPT ON 2
    END
    Doing it as described, i don't believe you need any of the INTERUPT commands.
    I assume you're posting because it's not working.
    hermann
    405
    2,597
    • November 1, 2024 at 10:26 AM
    GLOBAL INTERRUPT DECL2WHEN bIR_HALT==TRUE DO IR_HALT()
    INTERRUPT ON3
    Different numbers in statements.
Similar Threads
  • retract robot after Arctech Collision sensor activation
    • sloopkogel
    • January 27, 2024 at 7:26 AM
    • KUKA Robot Forum
