Have any of you used the Change gain option? Could you explain how it works?
Manuals attached.
You have 2 options in Kawasaki to reduce 'rigidity' to allow relaxation of motor torques.
- Soft absorber
- Change gain
These are commonly used in applications where the robot is being used to 'push against' external peripherals. like placing a gripped object into a tight area where tolerances require relaxation on motor torque(s) to prevent collision damage, but allow fitting of object.
- Meshing 2 gears together.
It's a best if you write more details about application and require to adjust the function. Here is an example of how a looks soft absorber in "two options":
1) tool aligning - it's just a simplified name for static force
2) main soft absorber - where robot adjusts the position to external force, in this case, clamp in machines, to not to force the machine.
