Hi guys,
I am trying to use Sunrise.FRI on the KUKA IIWA 14 R820 for my research project.
After setting it up as prescribed by the manual, I am unable to get the example projects to work. I am consistently getting met with the "Timeout before FRI connection quality reached GOOD or EXCELLENT" error message when trying to run the example projects.
After digging a bit deeper, I found that the external PC cannot "find" the controller's KONI interface, which may be the issue. I pinged the IP address set in Workbench (192.170.10.2) from my external PC and it says it cannot be reached.
Here are some things I have already tried, as suggested in the manual and other posts in this forum:
- Ensured that the PC (192.170.10.200) and KONI (192.170.10.2) IP addresses and subnet masks (255.255.255.0) are compatible. For reference, the IP addresses for the KLI connection are 172.31.1.147 (controller) and 172.31.1.1 (PC) with a subnet mask of 255.255.0.0
- Direct point-to-point connection between the KONI interface and PC
- Disabled the PC's firewall
- Ensured the cables and ports are in good working condition
- I have tried pinging the KONI interface using Windows and Linux
If somebody here has experience with Sunrise.FRI, can they please provide some advice to overcome this issue?
Thank you kindly in advance!
