  4. ABB Robot Forum
command to reduce the robot's speed
  • wiciu_88
  • October 23, 2024 at 10:51 PM
  • wiciu_88
    15
    I'm testing the program and I want it to run slower.
    I can't remember this command.
    I want to give it at the beginning of the program.
    After passing this command, the robot should slow down to e.g. 50%.
  • bull_boxer454
    7
    14
    • October 23, 2024 at 10:55 PM
    • Best Answer
    Look up Velset.
    It will be something like velset 50,3000;
    The first number is the percentage of programmed speed it will run, the second is the maximum speed. Make sure to have a command to turn it back to 100% when you're finished or the robot will continue to run at 50% speed.
  • wiciu_88 October 23, 2024 at 10:59 PM
    Selected a post as the best answer.
  • wiciu_88
    15
    • October 24, 2024 at 7:21 AM
    Velvet don't change me this speed :thinking_face: other comands to change speed in percent and show it??
    Images
      • 420.6 kB
      • 1,600 × 1,200
      • 5
  • Alex H
    5
    44
    • October 24, 2024 at 1:15 PM
    VelSet and the override in the menu are 2 different things and will both be taken into account for the final speed the robot is doing
    so VelSet works, but will not show up as a change of override percentage
  • wiciu_88
    15
    • October 24, 2024 at 3:22 PM
    Is some command to change override percent?
  • Lemster68
    301
    2,485
    Blog Articles
    7
    • October 24, 2024 at 4:21 PM
    No, there is not.
  • wiciu_88
    15
    • October 25, 2024 at 11:07 AM
    Can i change in system that if somebody turns from manual to auto it will be 50%?
  • Mr.Robot
    65
    • October 25, 2024 at 12:42 PM
    You can use the system input "Limit Speed"
    When the System Input Limit Speed signal is set to 1, the speed changes to a configured value. Once reset, it returns to the programmed speed.
    Edited 2 times, last by Mr.Robot (October 25, 2024 at 1:39 PM).
Similar Threads
  • Approximating acceleration profiles for PTP motions
    • nicok
    • November 6, 2023 at 5:16 PM
    • KUKA Robot Forum
  • Any suggestion how to resolve KSS01205 Ackn.: Interpolation cycle timeout monitoring LRS_HP issue
    • Aivaras Narbutas
    • September 11, 2023 at 3:43 PM
    • KUKA Robot Forum
  • Moving at the same speed indipendently of the percent my robot is running.
    • ToccoEnorme
    • June 1, 2023 at 8:27 AM
    • KUKA Robot Forum
  • Motion approximation when ARP is stuck
    • mudanda
    • September 16, 2022 at 12:46 PM
    • KUKA Robot Forum
  • KUKA does not reduce speed in safety room
    • Fubini
    • August 3, 2022 at 8:40 AM
    • KUKA Robot Forum
  • Normalizing speed along path
    • Marco
    • July 20, 2016 at 8:17 PM
    • KUKA Robot Forum
  • Clicking noise on A4 to A6 axis KR6
    • evo85210
    • April 13, 2022 at 11:27 AM
    • KUKA Robot Forum
  • Down the rabbit hole...Who wants to join in the fun?
    • Elderwild
    • November 30, 2021 at 8:25 PM
    • ABB Robot Forum
  • how to skip KRL and send command to motors directly
    • ArthurWong
    • April 20, 2021 at 12:07 AM
    • KUKA Robot Forum
  • Error E6007
    • DChernyshev
    • September 23, 2020 at 7:12 PM
    • Kawasaki Robot Forum
