Fanuc - Searching For A Register
  • MH-Robot-123
  • October 23, 2024 at 2:17 PM
  • MH-Robot-123
    I am wanting to find every program that has R[1] in it. Is this possible? Or do I need to manually go through each program. Tried using the search tool in the web server from the robot IP, but nothing came up. Thanks!
  • MOM October 23, 2024 at 3:35 PM
    Approved the thread.
  • jstolaruk
    16
    189
    • October 23, 2024 at 5:13 PM
    Try searching for "[R1" instead. If the register has a comment, a search for "R[1]" won't show because of the comment: "R[1:<comment>]".
    Edited once, last by jstolaruk (October 23, 2024 at 7:25 PM).
  • PnsStarter
    92
    329
    • October 25, 2024 at 8:37 AM
    Hi MH-Robot-123,
    As jstolaruk wrote . (Typo "Try searching for "[R1"" ------>"R[1")
    But keep in mind that you won't find Registers that are called
    - indirect like R[AR[1]]
    - like "CALL SET_INT_REG(1,45.678)
    Backdate/TP-Tools: A small collection of tools that simplify the commissioning and programming of Fanuc robots. (github.com)
  • jstolaruk
    16
    189
    • October 25, 2024 at 5:08 PM
    Quote from PnsStarter
    Hi MH-Robot-123,
    No, its not a typo. Leave the trailing brace off in the search, that allows R1 to have a comment and be found by the search.
    Good point about the indirection.
  • gpunkt
    121
    466
    • October 29, 2024 at 4:11 PM
    Quote from jstolaruk
    Sorry, but when you wrote "[R1", that must have been a typo. The left square bracket comes after R.
    Searching for what you wrote hopefully wouldn't yield any results...
  • jstolaruk
    16
    189
    • October 30, 2024 at 7:48 PM
    Quote from gpunkt
    My bad, thank you
  • EndAffector
    10
    33
    • October 31, 2024 at 5:37 PM
    This is not easily done in the teach pendant if you are looking across multiple programs. I would suggest saving all TP programs as ASCII (.LS) to a USB stick and search the files on you PC. Text editors such as Notepad++ and VS code allow you to search all files in a specific folder without having to open each file.
    Keep in mind that you will not be able to search KAREL programs unless you have the original non-binary file.
  • jstolaruk
    16
    189
    • October 31, 2024 at 7:01 PM
    Quote from EndAffector
    Easiest way is thru the website that the robot controller hosts, all of the tools are there.
  • gpunkt
    121
    466
    • November 1, 2024 at 1:27 PM
    Given that it's a PLUS generation controller.
    For older (R-30iB, R-30iA, R-J3xx and so on) there is no search tool from the web interface. :unamused_face:
Similar Threads
  • A website: Know FANUC alarm codes
    • linuxsand
    • October 20, 2015 at 12:30 PM
    • Manuals, Software and Tools for Fanuc Robots (you should look here first before posting)
  • Monitoring Serial Port
    • Drew Cable
    • May 18, 2023 at 7:33 PM
    • Fanuc Robot Forum
  • Fanuc monitoring software
    • yootommy
    • March 27, 2023 at 3:47 PM
    • Fanuc Robot Forum
  • How Do Third Party Vision Systems Communicate with A Fanuc Controller?
    • aMaintenanceGuy22
    • September 23, 2022 at 3:16 AM
    • Fanuc Robot Forum
  • Roboguide questions
    • robotecnik
    • July 26, 2022 at 3:01 PM
    • Fanuc Robot Forum
  • Fanuc Roboguide "Export I/O comments" no longer available
    • gumbi
    • February 6, 2021 at 3:59 PM
    • Fanuc Robot Forum
  • REGISTER
  • R
  • search
Users Viewing This Thread
  • 3 Guests
