Hello everyone, I wanted to ask you how to do a synchronized job with r1+s1:1, I usually always worked with a normal job r1+s1 but now I have to make a program for a bucket that requires a collaboration with basses and robots, if someone can help me explain how it works, I would be grateful.
Best regards
Fly Typhoon -
October 22, 2024 at 7:30 AM -
In the Create New Job screen, you pick the hardware from the Group Set drop-down.
You're right, I noticed it, but why when I insert a movement it gives me two.
Example = movl 50
----------------Movj 50 =? -
Example = movl 50
----------------Movj 50 =?When your group is R1+S1:S1, you will have two MOV instruction, first MOV is for robot position and second MOV is for positioner.
Now I'm starting to understand so when I press insert+enter it gives me let's say two movements because it's in sync mode
Also you can use another control group, R1+S1 but the isn't coordinated and sync, in this group you have only one MOV but this MOV have data position for robot and positioner in behind it.
So when I use a coordinated job only smovl and smovc can be used for synchronization between robot and base
You can also use SMOVS if necessary.
For 95devils and TSGIR I thank you for all your time and support in helping us in difficult times at work
Hi everyone, I would like to update you. I managed to make a synchronization movement for the first time. I'll post a photo for you.
