FANUC Emergency stop TP
  • NathanJo
  • October 11, 2024 at 2:48 PM
  • NathanJo
    68
    I'm on the hunt for the Fanuc emergency stop! In my code, I need to ensure the robot halts when the E-stop is activated. Do you happen to know which input the E-stop connects to?
  • cking8177
    10
    36
    • October 11, 2024 at 3:16 PM
    A Fanuc robot will (should) always stop when the E-Stop is activated, as this circuit is hard-wired. No programming is necessary to achieve this. Do you have a robot that, for some reason, does not do this? Or are you trying to use external E-Stops to halt the robot? What model robot/controller do you have?
  • NathanJo
    68
    • October 11, 2024 at 3:22 PM
    Quote from cking8177
    I'm developing a TP code to run the robot, and there will be an HMI to oversee the process moving forward. It will have an emergency stop, and that's where I'll apply this strategy.
    I’m unable to identify the input number that activates the E-Stop within the code.
  • cking8177
    10
    36
    • October 11, 2024 at 3:36 PM
    Quote from NathanJo
    Ah, this would be considered an "external" E-Stop, as it's part of a control system that is external to the robot's own wiring. There are two circuits on the robot's E-Stop board designed to be run through a set of relay contacts on an external safety relay. The location of these circuits on the E-Stop board does vary, so you'll want to find the electrical maintenance manual for whichever controller you are using.
  • NathanJo
    68
    • October 11, 2024 at 4:01 PM
    Is there a method to determine which input gets triggered when the TP emergency stop is activated?
  • cking8177
    10
    36
    • October 11, 2024 at 4:17 PM
    Quote from NathanJo
    These circuits are not normal inputs/outputs, but rather hardwired circuits directly to/from the E-Stop board. By default, no digital inputs/outputs are actuated when an E-Stop is pressed. You cannot use a typical input or output for a safety application, as those signals are not redundant and cannot reliably indicate a hazardous condition.
    If you want to use the status of the teach pendant or controller E-Stop in your programming (which does NOT count as an E-Stop, but simply a status indicator), you can set up digital outputs to be triggered under Menu->I/O->Interconnect->Press F3 [SELECT] -> "ES->DO." This lets you assign specific digital outputs to be triggered when any one of many safety faults occur.
  • HawkME October 11, 2024 at 5:24 PM
    Moved the thread from forum Manuals, Software and Tools for Fanuc Robots (you should look here first before posting) to forum Fanuc Robot Forum.
Similar Threads
  • Fanuc M-1000iA / R-30iB Plus
    • E_C_A
    • December 18, 2023 at 9:11 AM
    • Fanuc Robot Forum
  • System variables
    • GoodFellas41
    • June 26, 2024 at 9:47 AM
    • Fanuc Robot Forum
  • Question about safety circuit fanuc robot
    • Reflex
    • June 12, 2024 at 2:45 AM
    • Fanuc Robot Forum
  • SRVO-007 error alone, no seeming fix
    • EPeters1
    • August 25, 2023 at 7:33 PM
    • Fanuc Robot Forum
  • Alarms in a scara SR-6iA robot with a R30iB compact plus controller
    • robotecnik
    • September 18, 2023 at 9:21 AM
    • Fanuc Robot Forum
  • DCS Safe I/O Alert Triggering When Safe "@SSO[3]=@SPI[9]"
    • CheckMiniMap
    • July 19, 2023 at 10:13 PM
    • Fanuc Robot Forum
  • Program ABORTED in Auto mode
    • jagroop77
    • January 12, 2023 at 12:32 PM
    • Fanuc Robot Forum
  • Safety Fence and Light Curtain Wiring
    • zrehlander
    • March 28, 2022 at 6:22 PM
    • Fanuc Robot Forum
  • SRVO-105 alarm and no power to e-stop board
    • huffnpuff11
    • November 2, 2020 at 10:27 PM
    • Fanuc Robot Forum
  • Emergency Stop
  • fanuc lr mate 200 id
