How to connect a new gripper on kuka
  • Pafol
  • October 7, 2024 at 7:55 AM
  • Pafol
    Hello, I am planning to purchase a DH-robotics gripper for Kuka kr6 with KR C4 compact controller. I can't figure out how I should connect it (Gripperspottech installed). The AG-95 supports various protocols: TCP/IP, USB2.0, RS485, I/O, CAN2.0A, Ethernet (optional), Profinet (optional) and there is a protocol converter(CTS-B1.0).
    Is there any instruction or manual for such a case? Ask for any help.
    Edited once, last by Pafol (October 7, 2024 at 8:00 AM).
  • panic mode October 7, 2024 at 3:56 PM
    Moved the thread from forum Manuals, Software and Tools for KUKA Robots to forum KUKA Robot Forum.
    panic mode
    1,280
    13,085
    • October 7, 2024 at 4:15 PM
    GripperTech is tech option used to setup and control grippers after they are mapped to robot I/Os. So to use GripperTech, first you need to get the robot to talk to it. And for that you may want to contact manufacturer for any examples. The simplest options would probably be to use converter with fieldbus that robot supports (EtherCat/ProfiNet).
    And while that will get you access to gripper I/O, there is a good chance that you may still need to do some programming yourself.
  • Pafol
    • October 8, 2024 at 11:03 AM
    Quote
    Thanks for answer)
    Recently got an image using a converter. I will look for information on working with EtherCat, I/O protocols in WorkVisual
    Images
      • 144.11 kB
      • 741 × 611
      • 10
Similar Threads
  • KUKA KR240 R3200-2 PA HO robot's Amphenol connector type ( at A5 flange) ?
    • spp
    • September 24, 2024 at 2:17 PM
    • KUKA Robot Forum
  • Autoext kvp+eth only
    • WdeOliveira
    • August 12, 2024 at 12:40 PM
    • KUKA LBR IIWA
  • TCP/IP sockets communication with KR C5 micro
    • CoTer
    • March 29, 2024 at 3:49 AM
    • KUKA Robot Forum
  • Reset the current running program
    • Edward Kim
    • August 23, 2022 at 4:08 PM
    • KUKA Robot Forum
  • Cross connecting Output-Output
    • vvvvv
    • April 28, 2022 at 1:27 PM
    • KUKA Robot Forum
  • Finding solution plan for simulate gripper.
    • Bas Tawinwongsuriya
    • August 27, 2021 at 6:47 AM
    • KUKA Robot Forum
  • Work visual doesn't accept .xml​
    • Just Me
    • March 29, 2021 at 5:09 PM
    • KUKA LBR IIWA
  • How to make a communication between kuka controller other hardware controller?
    • Sotheaveas
    • November 24, 2020 at 10:47 AM
    • KUKA Robot Forum
  • Robotiq Gripper Configuration in WorkVisual through EtherCAT
    • qumo2016
    • March 23, 2017 at 1:30 PM
    • KUKA Robot Forum
  • Expand 7th joint limit with arm rotation [with code]
    • olivier.ho
    • September 22, 2020 at 8:03 PM
    • KUKA LBR IIWA
