I have attempted to install FANUC Rooguide multiple times; however, I have encountered several errors. Do you have any insights on this matter?
Can not install the FANUC simulator
NathanJo -
October 4, 2024 at 3:41 PM -
Nation
October 4, 2024 at 3:46 PM Moved the thread from forum Manuals, Software and Tools for Fanuc Robots (you should look here first before posting) to forum Fanuc Robot Forum. -
It would help if you listed what the errors are.
I have indeed captured the screenshots.
Post
RE: Roboguide installation problem in Windows 11
I am running ROBOGUIDE on a Windows 11 computer without any problems. Install revision T first and after that, you can install a newer revision. Simply confirm the upcoming error messages and continue the installation. It is important to install ROBOGUIDE as administrator.DS186February 29, 2024 at 1:53 PM -
I’ve uninstalled the roboguide and I’m looking forward to putting it back on. I just can’t figure out what’s going on!
Looks like you don't have admin rights.
Did you run the setup as admin?
Yes. It functioned nicely in the past, but after the evaluation period was over, we were unable to install it anymore.
When your evaluation license expires, you just need to enter your license data into the Fanuc License Manager, no re-installation required.
Why are you trying to re-install it?
I realize I made an error since I didn't know about it earlier. I'm currently trying to reinstall the older version I had, despite it being expired, and I'm also figuring out the license settings. Does that sound correct?
