SFT ON / SFT OFF Wierd
  • Utschka
  • October 2, 2024 at 2:01 PM
  • Utschka
    17
    Hi Guys,
    My depalletizing program is currently trying to depalletize boxes from a container. The boxes are stacked in the container. There are a total of 6 layers that need to be depalletized. After each depalletized layer, the user frame with the corresponding position variables (P1-P6) is moved down by the corresponding offset. This process is repeated until the entire container has been emptied. The problem with this is that only the approach and the positions of the boxes are to be shifted by the offset, but not the position above the container from which the boxes are transported to the conveyor belt. The position variables P1-P6 are specified in reference to user frame #1 and it is precisely this that is shifted downwards or upwards by an offset of z = 150000 using SFTON P[0] UF#(1). The other position variable, which should remain fixed, is assigned to user frame #3, so I thought that this would be excluded from the SFT operation, but this does not seem to be the case. After the SFT ON, all positions are shifted by the specified offset regardless of which user frame they are assigned to. Is there another way to really only move the positions that are linked to the userframe? The jobs for the individual boxes are called up by a master job, which is also responsible for the shift. Here is my code :
    MASTER :
    /JOB
    //NAME M4STER
    //POS
    ///NPOS 0,0,0,0,0,0
    //INST
    ///DATE 2024/10/02 08:13
    ///ATTR SC,RW
    ///GROUP1 RB1
    NOP
    SETE P[0] (3) 150000
    SET D051 150000
    SET B050 0
    WHILE B050<6
    CALL JOB:P1D
    CALL JOB:P2D
    CALL JOB:P3D
    CALL JOB:P4D
    CALL JOB:P5D
    CALL JOB:P6D
    SFTON P[0] UF#(1)
    ADD D051 150000
    SETE P[0] (3) D051
    INC B050
    ENDWHILE
    END
    !!!!Now job P2D!!!
    /JOB
    //NAME P2D
    //POS
    ///NPOS 0,0,0,0,0,0
    ///TOOL 0
    ///POSTYPE PULSE
    ///PULSE
    //INST
    ///DATE 2024/10/02 12:39
    ///ATTR SC,RW
    ///GROUP1 RB1
    NOP
    MOVL P[21] V=1000.0 PL=0
    MOVL P[2] V=1000.0 PL=0
    MOVJ P[100] VJ=100.00
    END
    Here again the last instruction (MOVJ P[100] VJ=100.00) from P2D should not be moved. Unlike the others, this one is also specified in reference to user frame #3 and not to UF#1 like all the other positions, so I don't really understand why this one is also moved. I'm fairly new to programming Motoman robots so please be forgiving of any obvious mistakes or errors in reasoning on my part. Thanks in advance!
  • Nation October 2, 2024 at 2:20 PM
    Approved the thread.
  • Mike01TJ
    34
    • October 2, 2024 at 3:55 PM
    SFTON will shift everything until the SFTOFF command.
    95devils
    229
    8
    1,930
    • October 2, 2024 at 4:24 PM
    Where is your SFTOF instruction?
  • Lembeck
    • October 3, 2024 at 12:44 AM
    What Mike said above is 100%
    If P2 is the only one you want to change height why not edit the z height for this move instead of doing that for P0 for the shift?
    also if your controller is DX200 or older ditch the PL0 from your moves and put a 0.05sec timer on the line after the move, it will have the same effect with less of a time penalty.
    Edited once, last by Lembeck (October 3, 2024 at 12:50 AM).
  • Utschka
    17
    • October 7, 2024 at 7:18 AM
    Quote from 95devils
    I expect that the SFTON only shift the Positions linked to the USERFRAME #1, thats why i dont used SFTOF
    Edited once, last by Utschka (October 7, 2024 at 7:31 AM).
  • Utschka
    17
    • October 7, 2024 at 7:24 AM
    Quote from Lembeck
    No, what i want is that all Six Positions excluding P[100] change height for every run in the loop. Can u explain your other idea with the timer further, as i said im quite new at Motoman Programming :smiling_face:
    Edited once, last by Utschka (October 7, 2024 at 8:09 AM).
    95devils
    229
    8
    1,930
    • October 7, 2024 at 11:02 AM
    Quote from Utschka
    When the SFTON instruction is executed, it stays on until the SFTOF is executed, even if a job is called or jumped to.
  • jarm
    247
    • October 7, 2024 at 2:27 PM
    The UF in the sfton instruction just indicates which UF the shifting is happening in, nothing more
  • userframe
  • shift
  • depalletizing
