  5. Manuals, Software and Tools for Fanuc Robots (you should look here first before posting)
Program Call Graph Generator Web App
  • Nation
  • September 29, 2024 at 11:26 PM
  • Nation
    Typical Robot Error
    522
    1,900
    I've created a small web app that will generate the CALL graph hierarchy from a full MD: backup. It parses the .ls files, and looks for CALLS to other programs. Just zip up the backup, with no directories inside.
    Using this tool, you can see what programs get called from where, and if there are any isolated programs in your backup.
    Give it a try here: https://synapticrobotics-robotbackupcallgraph.web.val.run/
    Your backup is deleted after the analysis is done.
    Hovering over a program node will show what nodes it calls as orange. It will also show nodes that call it as blue. If a call is made to a program that isn't present in your backup (such as a system level karel program) it will show up as red. Programs that are present will show up as green.
    You can also click and drag nodes around if you like, and also save a high resolution .png of the graph using the button below the graph area.
    Short video of it in action:
    Call Graph.mp4
    Current issues:
    • Macro calls are not supported.
    • Run commands are not supported.
    Let me know if you have any issues with the tool.
  • cattmampbell
    16
    • September 30, 2024 at 6:45 PM
    Whoa, this is very nice. Thank you for sharing!
  • massula
    200
    8
    1,426
    • September 30, 2024 at 7:54 PM
    Waiting for something like this for so long... thanks, Nation!
  • EnergyAddict
    45
    133
    • October 15, 2024 at 4:54 PM
    I've tried uploading several different backups, and I continue to get the message:
    "Upload rejected: The zip file contains directories. Please upload a zip file with files only."
    I don't have anything other than files in the zip.
  • Nation
    Typical Robot Error
    522
    1,900
    • October 16, 2024 at 12:57 AM
    Hmm. Would you message the backup to me directly? I'll debug it.
  • Leviafun
    17
    • October 16, 2024 at 4:41 AM
    Quote from Nation
    I have the same issue. Can I help?
    Some backups are working, but only isolated nodes are displayed.
    I've tried to create a similar program before but just with .LS files. Why are you use MD backup and BACKDATE.DT? Are you planning to publish it to open source? Maybe I could test it or commit to it.
  • Nation
    Typical Robot Error
    522
    1,900
    • October 16, 2024 at 10:53 AM
    Quote from Leviafun
    I originally had more grandiose plans for the app, mainly parsing the macro structure. That would require the sysmacro.va file.
    I made it public if you guys want to fork it. It's a bit of a hot mess, as I used the townie AI to help write it.
    You can view the source here:
    @synapticrobotics/RobotBackupCallGraph
    An interactive, runnable TypeScript val by synapticrobotics
    www.val.town
  • Leviafun
    17
    • October 18, 2024 at 4:24 AM
    Quote from Nation
    https://www.val.town/v/synapticrobotics/RobotBackupCallGraph
    Only one question, could you explain why backup.zip should not contain any directories?
    For example, my MD backup creates the following folders (120iC, R30iB V9.10, created in Roboguide):
    D:.
    └───MNT_DATA
    ├───DLOG
    ├───MDB
    ├───MD_LS
    ├───RSCH
    └───_BACKUP_
    LS files are located in MD_LS, and the BACKDATE.DT is located in MDB.
    So, what format does your MD backup have?
  • Nation
    Typical Robot Error
    522
    1,900
    • October 18, 2024 at 11:19 AM
    I mainly did that to simplify the code on the server side.
    When I do a MD: backup, I just copy the entire contents of the MD: device into a folder via FTP. If I don't have FTP access, I do the same on the controller into a folder in the USB stick.
