Torch vibration problem when only operate B Axis and I was changed new motor but problem not solved also amplifier interchanged but problem as it is pl guide him
Yaskawa Mig robot Dx200
Mayur Panchal -
September 28, 2024 at 10:23 PM -
B-axis drive is damaged.
drive interchanged also but problem not solved
check your T axis as well.
T axis also checked but vibration not found only B axis operated then vibration come on torch
Do you have some immages or a small clip of how this happens?
It may be your R axis casting is bent. Did the robot crash?
Replace the wrist.
sir but only B axis moved then that time vibration come
What kind of move command did you use? MOVL, MOVJ,....
The fixed end of the B drive is attached to the R axis casting. If the R axis casting is bent, the B drive will not have a correct alignment to rotate on and as it turn it will cause the R axis to torque back to the correct alignment and cause this shake as it moves. If you don't believe me , make a job that only moves the B drive, slow, and then fast. you will see the 'shake' will correspond with the speed of the B drive motion. Thus, the B drive is pushing the bent R casting.
How to resolved problem B axis manual moved that time vibration come.
You can replace the R casting, but in my opinion you are better off replacing the whole wrist unit.
