Fanuc LR Mate 200id control
  • Omer Cebesoy
  • September 27, 2024 at 3:58 PM
  • Omer Cebesoy
    7
    Hello everyone,
    I can control the fanuc robot automatically and run it by remote starting via plc. By giving a start signal via uop (UI6 Start), I run the robot's code line downwards. What I need is to have the code go from bottom to top (backward button function). Where can I give control of this button to the plc? To which UI signal should I send a trigger from the plc?
  • hermann
    404
    2,595
    • September 28, 2024 at 9:39 AM
    You can't.
  • sborchshev
    35
    • September 30, 2024 at 9:35 PM
    You cannot reverse program execution. Only option would be two programs one is in one direction, the second would be in backwards. You can set steps in programs to be able to pick up from other then beginning/end. Use PNS program switching and send four input binary code from PLC to switch programs. only one motion program can be running in a time.
Similar Threads
  • Plc with roboguide
    • Moises
    • September 15, 2018 at 9:16 AM
    • Fanuc Robot Forum
  • Fanuc LR mate 200iD io
    • muhammedsuhail1997
    • August 14, 2024 at 2:53 PM
    • Fanuc Robot Forum
  • PC and FANUC robot TCP/IP Communication
    • mahboobelahi93
    • September 24, 2021 at 4:02 PM
    • Fanuc Robot Forum
  • CVIS-088 Vision FPGA version error
    • baz
    • June 6, 2023 at 9:29 PM
    • Fanuc Robot Forum
  • J2 and J5 buttons not working.
    • irongient
    • March 22, 2023 at 4:45 PM
    • Fanuc Robot Forum
  • FANUC Camera Noise, Hand mounted Camera
    • diey
    • July 18, 2022 at 6:53 AM
    • Fanuc Robot Forum
  • TCP/IP communication only for Fanuc R-30 iB Mate plus to Siemens PLC (S7-1500)
    • Aidan Mundle
    • December 3, 2021 at 4:05 AM
    • Fanuc Robot Forum
  • Roboguide with Ethernet GigE Camera Basler
    • Antonin
    • June 15, 2021 at 2:40 PM
    • Fanuc Robot Forum
  • how to restart an aborted task, if RUN_TASK doesn't work, fanuc error code manual
    • FLrobotics
    • November 25, 2020 at 2:20 PM
    • Fanuc Robot Forum
  • Robot Tunning - Cable Impedance
    • lfbmarques
    • September 16, 2020 at 10:48 PM
    • Fanuc Robot Forum
  • fanuc lr mate 200 id
