wire sticking
  • yusuf
  • September 27, 2024 at 11:53 AM
  • yusuf
    40
    Hi all
    anyone can help me understand the how does the wire stcking work??
    even the wire doesn t stick the message of wire sticking appears a lot and cause a delay in the production line
    any help please
  • Robodoc
    56
    7
    1,061
    • September 28, 2024 at 2:13 PM
    Wire sticking is different in an analog or digital connection. What controller do you have? What weld power supply do you have? How is the welder connected to the controller (analog or digital)?
    Basically, if you are not welding and the controller senses the weld wire is touching ground you get "wire stick". This is most commonly caused by the weld wire touching ground (the liner passes through the fence to the bulk spool and chafes through and touches the fence, or the bulk spool is on the machine frame (always insulate the weld wire from ground)). Another thing to look at is the weld positive cable that runs up the arm of the robot. If the insulation has worn through it can touch the robot (that is grounded) and cause "wire stick" alarms.
    Robodoc
Similar Threads
  • wire sticking check
    • yusuf
    • September 25, 2024 at 1:44 AM
    • Yaskawa Motoman Robot Forum
  • shock sensor
    • idea
    • June 23, 2017 at 5:54 PM
  • Fanuc Wirestick function
    • Jeremyf22
    • March 13, 2023 at 3:15 PM
    • Fanuc Robot Forum
  • New Robot jerking after activation
    • robowreck
    • February 25, 2023 at 12:52 PM
    • KUKA Robot Forum
  • Arc-008
    • Goulash
    • May 19, 2022 at 7:26 PM
    • Fanuc Robot Forum
  • KRC2 problem with igniting arc with MIG welding
    • NoBugsOnlyFeatures
    • August 13, 2021 at 7:29 PM
    • KUKA Robot Forum
