  4. other Robots
Universal robot - How to rotate the gripper at the right angle?
  • WQRST
  • September 26, 2024 at 1:17 PM
  • WQRST
    5
    Hi guys!
    It's my first time with universal robot and i need help with gripper rotation.
    Let's imagine I have gripper with 10 suction cups and 2 sensors DI6,DI7. I have pallet with planks. Each layer is arranged at a different angle. I need to detect plank number "1" and rotate the gripper so that the suction cups are positioned perfectly over the plank.
    How do I measure the angle with these two sensors and how do I rotate the gripper by the specified angle?
    Planks are much larger than in the picture.
  • AustinC03
    Bagel Devourer
    28
    • October 8, 2024 at 10:29 PM
    Is each plank going to be in a different orientation each time?
    What devices are you using to define these orientations?
    If so I don't see this being easy to accomplish without a vision system to locate the plank each time consistently.
  • WQRST
    5
    • October 15, 2024 at 9:45 AM
    Austin, we need to detect each layer and first plank of layer with 2 optic sensors.
  • xavier.rob
    • October 16, 2024 at 3:07 PM
    If each carton has a different and random orientation. Put a camera rather than your 2 sensors. The cost will be largely profitable over the time you will take to create, and develop your solution. As well as on the maintenance time on the life of the machine (especially at the beginning of the life of your machine)
  • AustinC03
    Bagel Devourer
    28
    • October 16, 2024 at 4:43 PM
    Correct me if I'm wrong here, but you're attempting to use light ray based Optical sensors?
    I feel like a camera would benefit you a lot more here.
    Unless you have steady lighting and a completely different background color pallet it will be more difficult to replicate the correct pick each time while allowing the Sensors to adjust accordingly
  • angle
  • Gripper
  • Rotate
  • Universal Robot
