ELIAS
  • khoury elias
  • September 17, 2024 at 7:32 AM
  • khoury elias
    I don't have any experience in the ROBOT program but I have a problem and I need to solve it .
    We have a Fanuc RJ3 robot that communicates with a SIEMENS S7-300 PLC via PROFIBUS protocol. When I start the robot, it does one movement and stops at line 255 of the program
    254 : ! WARTE FRIEGABE SENKEN
    255 : WAIT DI[11]=ON
    256 : LBL [32]
    257 : !SENKEN ZUM ZIEL
    258 : GO[1] =64
    259 : R[255]=PR [12,3]
    What does that mean and where is DI[11] i cannot find it on the EE Plug
    many thanks
  • kwakisaki September 17, 2024 at 8:31 AM
    Approved the thread.
  • saberlars
    Robot, beyond Human..
    22
    225
    • September 17, 2024 at 10:15 AM
    If, that "Di11" Signal from PLC
    Check out PLC Logic.
    Or from CMR2A (CMR2B) Cable,
    Check out external contactor.
    Press [I/O] - F1 - Digital - F2 (Config)
    ABB, FANUC, Hyundai, Kawasaki
  • Andi_33
    • September 17, 2024 at 10:21 AM
    In line "255: WAIT DI[11]=ON," the robot is waiting for Digital Input [11] to receive the value TRUE. I assume that the inputs value is changed by the PLC. The issue is likely that the PLC isn't setting this value to TRUE because certain conditions aren't met, or a sensor connected to the PLC isn't providing the correct value.
    I just noticed line 254: "! WARTE FREIGABE SENKEN." Your robot is waiting for the release signal to move down. This means that the signal DI[11] is likely set by the PLC, and the PLC is waiting for a sensor to release the robot. So this sensor might be the problem.
    Edited 2 times, last by Andi_33 (September 17, 2024 at 10:29 AM).
  • khoury elias
    • September 18, 2024 at 6:07 PM
    Thanks guys,
    I found the problem today, it was in the photocell sensor which connected to the PLC, so we replaced it and everything was fine until the robot moved to the wood pallet tank and it stopped at the top .the Fanuc Pendant shows this screen.
    Can you plz help me, I don't know if this problem is with the ROBOT or maybe another sensor
  • pdl
    266
    1,508
    • September 20, 2024 at 9:49 PM
    Can you post the code from MOVE.TP? If not, can you search for a line of code that says:
    SKIP CONDITION=xxxx
    And post a picture?
  • khoury elias
    • October 14, 2024 at 10:14 PM
    Hi guys
    I have 2 Plug on the robot (EE & AS-2)
    i know the pinout of the EE Plug
    but can i have help about the AS-2 pinout
  • DS186
    199
    1,051
    • October 14, 2024 at 10:46 PM
    AS is the user cable interface. There are different pinouts, depending on your robot model and the user cable option. Check the manual of your mechanical unit for detailed information.
Similar Threads
  • How to set up a used robot from scratch..
    • eliasgr
    • December 27, 2021 at 4:30 PM
    • KUKA Robot Forum
  • Change UI language on KRC Software V5.5.10 KRC2 Win XP ed.
    • vineeee
    • October 30, 2017 at 6:53 PM
    • KUKA Robot Forum
  • Digital I/O
