Hi I'm using E controller with sca sealer system. I could able to apply sealer in automode. But i need to check sealer in fastcheck mode with sealer application. I'm using CL1 for sealer gun on. But the particular signal turns on only in automode. Is there any way
Sealer on in teach mode
vipinpunneri -
September 12, 2024 at 3:34 PM -
No idea and to be honest I've never looked into that as I cannot see the point of it personally.
All I remember is the SPRAY ON/OFF is the global control if you were in teach mode you had to turn on the gun output signal manually, so not sure in fast check whether this can also be done and/or via executable code.If it doesn't work in fast check then I would assume the answer to be it's not available.
May be it has been implemented since in later AS revisions, but that's something you would need to ask your local distributor. -
Okay thank you for the update. I thought some maintenance switch changes will do this for me.
I've looked and cannot find anything conclusive.
If you fire an email over to your local rep, I'm sure they will look into it for you though.
