I am replacing a R2000iB 210F on an older RTU with a R2000iC 270F on a new Fanuc RTU. The problem I am having is the robot dose not mount in the same location on the RTU so I am having to add 450mm to each position in the programs. Is there a way I can do this without manual adding to each step?
Currently I am using Roboguide and saving the program as an .LS file adding 450 to E1 and importing it back.
