BasisTech Functions in SPS.sub
  • Jeulin
  • September 4, 2024 at 11:50 AM
  • Jeulin
    Hi Everyone !
    I work as a medical robotics engineer. I currently use a KUKA KR 160 R1570 nano, with a KRC 8.7.5 and I use WV 6.0.
    When I took over the company's existing project, I came across 2 functions that I can't find any mention of in the manuals on KukaXpert (Handbooks, Manuals...). The same goes for the forums.
    The functions are BasisTech_PLC_INIT() and BasisTech_PLC_LOOP() in the SPS.sub subroutine.
    The system works with an external Siemens PLC.
    I don't really undertsand the name of the functions, why ‘PLC’ here ? When I look into the functions it seems there is nothing to do with the PLC...
    Here is the content of the functions, defined in System/bas.src :
    GLOBAL DEF BasisTech_PLC_LOOP()
    DECL KRLMSG_T MSG
    DECL KRLMSGPAR_T MsgPar[4]
    DECL KRLMSGOPT_T Opt
    DECL BOOL bDummy
    MSG.Nr = 6789
    MSG.MODUL[] = "TechHandler"
    MSG.MSG_TXT[] = "EasyTeachKeepOriWarning"
    Opt = {VL_STOP FALSE, CLEAR_P_RESET FALSE, LOG_TO_DB TRUE}
    IF EasyTeachKeepOriWarning THEN
    IF EasyTeachKeepOriHandle == 0 THEN
    EasyTeachKeepOriHandle = SET_KRLMSG(#State,MSG,MsgPar[],Opt)
    ENDIF
    ELSE
    IF EasyTeachKeepOriHandle > 0 THEN
    bDummy=Clear_KrlMsg(EasyTeachKeepOriHandle)
    IF bDummy THEN
    EasyTeachKeepOriHandle = 0
    ENDIF
    ENDIF
    ENDIF
    END
    And
    GLOBAL DEF BasisTech_PLC_INIT()
    UpdateLoadModes ( )
    InitHomePositions ( )
    END
    Does anyone have a description of these functions ? Are they mandatory ?
    Thanks in advance for any help,
    Sincerly,
    Jeulin.
  • Fubini September 4, 2024 at 1:45 PM
    Approved the thread.
    Moved the thread from forum General Discussion of Industrial Robots Only to forum KUKA Robot Forum.
    panic mode
    1,280
    13,082
    • September 4, 2024 at 2:33 PM
    in case of KRL some variable declarations can be seen in various files, others are not (compiled into KSS).
    this is so called basis package...
    also, more variables can be introduced by installing additional tech packages (software options).
    but as with any program, declared variables need initialization.
    in SRC file there is an INI fold where robot program related variables get initialized.
    when options are installed, they insert their own initialization into INI fold.
    the same goes for Submit interpreter...
    so things that need initialization are processed by call to BasisTech_PLC_INIT() which of course is only done once.
    but... Submit is background process that runs all the time. and things that need continuous processing is placed in BasisTech_PLC_LOOP()
    anything named BasisTech is internal to KSS and best left alone. never needed to look into it.
  • SkyeFire
    1,051
    9,426
    • September 4, 2024 at 3:43 PM
    Quote from Jeulin
    This is a translation artefact. "SPS" is an abbreviation for a German term for PLC -- basically, the SPS is the "background PLC" for a KRC. Whoever wrote the BasisTech_PLC routines was probably using English terminology. So these routines are probably completely internal (possibly part of a specific Tech Package, check your KRC's installed options for "Easy Teach" or "Keep Ori"), and despite the name, have nothing to do with your extrenal PLC.
  • Jeulin
    • September 4, 2024 at 4:22 PM
    Quote from panic mode
    Hi ! Thanks for your answer ! (Big fan here :sneezing_face:)
    I understand that I should not dive into it but since I'm working in a medical field we have to follow several standards (here IEC 62304). And this standard requires us to describe in documentations all the SOUP (Softwares Of Unknown Provenance) we have in the code and why we use it. That's why I was wondering about a description for those. I'll try to check for the packages, maybe I can find more informations there.
    Thanks again,
    Sincerely,
    Jeulin.
  • Jeulin
    • September 4, 2024 at 4:25 PM
    Quote from SkyeFire
    Hi ! Thanks for the answer too ! (So many famous people here:star_struck:)
    That's insane ! I didn't know about the meaning of SPS :o :o :o !
    I'll check theses packages and tell you what I found !
    Sincerely,
    Jeulin.
    panic mode
    1,280
    13,082
    • September 4, 2024 at 5:55 PM
    some common terms are in the READ FIRST topic. and of anything our members from Germany/Austria/Swiss should be able to help with:
