ALARM 4314
  • zsivon
  • September 3, 2024 at 12:40 PM
  • zsivon
    8
    Hello.
    We have a problem with the robot (EPX2900), namely the error alarm 4314 - serial encoder battery error, axis R/B/T (pictures in the attachment). After the reset, the robot continues painting.
    We replaced all the batteries (in the control cabinet and two pairs of batteries for axis 1, 2, 3, 4, 5, 6) but the error keeps repeating.
    Any idea what it could be (wiring / R/B/T axis motor)?
    Thanks in advance and best regards!
  • HawkME September 3, 2024 at 1:36 PM
    Approved the thread.
  • Robodoc
    56
    7
    1,059
    • September 7, 2024 at 2:20 PM
    Can be the harness in the arm. When was the last time the harness was changed?
    Robodoc
  • zsivon
    8
    • September 11, 2024 at 7:06 AM
    I don't know, probably a long time ago. Where is the harness location?
  • roboprof
    24
    467
    • September 11, 2024 at 5:38 PM
    Wire harness goes through the base of the robot arm all up through the lower and upper arm. It connects the base cables of the robot to all the motor and encoder connections of the 6 axes.
  • zsivon
    8
    • November 22, 2024 at 11:34 AM
    Hi.
    We still haven't figured out what the problem is.
    We found that at different robot locations, it sometimes displays an error on the joystick, and sometimes nothing. In both cases, it displays an error on the MOP, namely a robot cabinet error. After resetting, the error disappears and the robot continues to operate. The error occurs 1 - 2 times a day (8 working hours).
    Does anyone have an idea / solution?
    Thanks.
  • zsivon
    8
    • November 22, 2024 at 11:45 AM
  • 95devils
    233
    8
    1,946
    • November 22, 2024 at 1:33 PM
    Have you changed the harness in the arm yet?
  • zsivon
    8
    • November 25, 2024 at 7:09 AM
    Not yet. I have two in stock, I don't know which is the right harness axis L (HW0173560-A) or harness axis S (HW0173559-A).
    Edited 2 times, last by zsivon (November 25, 2024 at 12:49 PM).
