Hey all, been lurking for a little while now and found this to be the most helpful place to figure out various issues I have had.
Several of the units I am working with are Yaskawa YRC1000 Cobots paired with Miller Auto-Continuum 350s.
I am having trouble figuring out auto-retraction. After each weld on several of my robots it will auto-retract just enough to occasionally get the wire stuck back inside the tip, and will then break the wire at the feeder when attempting to re-arc on the next weld. I cannot find anything regarding retraction in the pendant, and on the welder power source itself I have both attempted to turn it down as far as possible and then turned it off completely.
Any ideas or solutions would be much appreciated. Thank you! -JD
