Hello, i have a problem with a KRC4 robot:
KRC4 KSS 8.2
KR180 R2500 Extra
The robot is doing palletizing and was ok before the installation - we tested it for a week.
The robot is working in automatic external as a device with a PLC controller Siemens S7 1200 as master.
All the signals for the gripper and the conveyor system + sensors are managed by the PLC.
We have this error: " Stop due to locked drive A4 "
where the locked axis can be anything from A1 to A6 - it is different all the time. The message cannot de acknowledged in EXT mode
The issue is appearing at random position, there are no singularities over the whole range of movement of the robot.
Any idea what can cause this? I am struggling to find any info about it
Stop due to locked drive A...?
vvelikov -
August 26, 2024 at 11:15 AM -
don't recall seeing this... "lock" is something usually seen with safety like SBM or SHB
the message number is low suggesting something that existed since KRC1/KRC2 times though it was not documented there either. also message itself does not seem to appear in any of the newer KSS versions either - the last KSS that did have it may be the KSS8.2...
my next thought was maybe it is part of the option such as SafeOperation or SafeRangeMonitoring etc but messages from those tend to be in 15000 or so.
the other problem is that you are looking at the messages only in the message view. this is bad. it is only list of current messages. and since you cannot find much about this one, you need to broaden the search. check what happened just before these messages (close timestamp) even if those other messages are no longer displayed. maybe they appeared only momentarily so.... check the message log.
reading message logs on the smartPad is hard. i would collect archive and use offline copy of LogViewer on my computer. this gives you not just more screen space, but also additional search options, faster interactions etc.
another thing i would look at are safety signals from PLC.
perhaps because safety PLC locks the robot - intentionally or accidentally (scan glitch or logic problem). check things like SHS1, SHS2, SBH, SBH1..6, UER1..16 etc. or create temporary program that forces them on. also could be network issue, (configuration, missing packet etc.). so i would try isolating this to as small of a LAN as practical (just robot, PLC and your computer) until further info is found.
at any rate, i hope this gives you something to try...
If you check for help you will find this
Thanks guys! I was really out of options with this " locked " messages... i will dig in the plc logic - we use it for all the ext signals, may be there is a glitch in the logic? Will check the logs and lets see where this will go...
Thanks again! Unvaluable help!
yes... that is the message...
and its value is to serve as brilliant example of something perfectly useless. and the proof is that both presence and absence of the this message would make absolutely no difference whatsoever, regardless who is standing next to that robot and looking at the teach pendant.
all adults (and specially robot developers, technical writers) should be forced to spend 5min to watch something like this. it would make them so much better in their work. when problems happen, users expect instructions...
As panic mode mentioned:
You only show the message. Normally you need to check "what happend" before!
Using log Viewer could be helpful.
Checking the files in the log and log\system directories could be also very helpful
HI,
You said the robot have tested for a week. Do you mean it is testing with PLC ?
I think you can check the power cable and the resolution cable.
if the connector is fine? how about the pin inside? if the connection well?
From your message, the error is not only for A4, It really looks like the cables are not connected well.
No, when tested there was no PLC connected.
The safety is X11, not through the PLC, we have only move nable signal through the plc signals and all the ext signals - for automatic external mode.
I will check also the cabling, thanks!
Hi again!
As i never used krcdiag before, feel a bit lost... on the end i think i found how to see the errors but they are not telling me anything usable.
I exported them so if someone can tell me what these registered errors mean...
here is a part of the messages:
Display More#1418: M_203 15:56:06.088 21.08.2024 M_203 Module: CrossMeld MsgNr: 203 #1419: M_26170 15:55:42.622 21.08.2024 M_26170 Parameters: KPP, 1, 0x00000200 Module: CrossMeld MsgNr: 26170 #1420: M_26118 15:55:42.591 21.08.2024 M_26118 Parameters: KPP, 1, 0x00000200 Module: CrossMeld MsgNr: 26118 #1421: M_26029 15:55:42.591 21.08.2024 M_26029 Parameters: 1 Module: CrossMeld MsgNr: 26029 #1422: M_1210 14:46:29.769 21.08.2024 M_1210 Module: CrossMeld MsgNr: 1210
what seem to be the problem? everything needed to troubleshoot is already stated...
open file in favourite text editor like Notepad++
verify time stamp order and note that in this case the newest messages appear at the top.
then search for your problem message, in this case 3154once you find one or more of them, see what messages are just before them.
for example i see this:
#104: M_3154
16:50:02.165 26.08.2024
M_3154Parameters: P_0
Module: CrossMeld
MsgNr: 3154#105: M_26170
16:50:02.149 26.08.2024
M_26170Parameters: KPP, 1, 0x00000200
Module: CrossMeld
MsgNr: 26170message #105 appeared 16ms before message #104.
that happen to be message number 26170then you lookup that message and see if that could be actual reason that you are seeing message 3154.
and that it is mains failure.
do you think that mains failure occurring 16ms before some axis is locked could be an issue? do you think that mains failure could affect any axis?
then you try to see how often that happens... and the log says message 26170 is mentioned hundreds of times. did you reboot controller so many times? or do those message appear also when you try to run robot?
that is obviously not a way to run production so you need find the problem, whatever is causing too large voltage drop... like too small transformer... or too small wire cross section or too long mains cable... or loose connection... but this could alco be due too large load... or too large acceleration. so for test lower the OV_PRO from 100 to 10 or 30% and trry again. do you still see the same issue?
one you find and fix this then you try it again and follow the process over and over until you weed out every issue...
It actuallly started before with error
then this message came up
With the explanation
parsing text file is not for everyone. which is why i suggested using LogViewer. go to robot D:\, under KSS installer there are some tools including LogViewer. install it on your computer add message files. then drag and drop archive or KrcDiag onto LogViewer window.
you can also get it from newer KSS as they are more polished. for example the newer ones allow you to have single LogViewer work with messages from different KSS versions.
then you have something much more user friendly than text editor
Thanks guys! That was really helpful!
Will see what the situation is tomorrow and write back -
Did you resolve this issue? We're having the same issue with similar mains phase error codes.
Yes, it was a problem with the power supply - they had problem with the power line
