Stick-Out - Touch sense
  • Joao Azevedo
  • August 22, 2024 at 9:15 PM
  • Joao Azevedo
    good afternoon,
    I'm new here and I need some support,
    Please see if you can help me,
    I have a welding cobot
    I would like to do a Job to adjust the Stick-out in more complex processes, before actually using the touch sense,
    I would like to
    retract the wire,
    Bring the torch close to the welding table,
    feed wire until it touches the table,
    thus ensuring that the Stick-out is always right,
    is it possible to do this?
    can you help me?
    Thank you for your attention
    :smiling_face::smiling_face:
    :smiling_face:
  • Lemster68 August 22, 2024 at 9:40 PM
    Approved the thread.
  • Robodoc
    56
    7
    1,059
    • August 24, 2024 at 1:59 PM
    buy a wire trimmer. Stop the robot, advance the wire, trim the wire and it's always the same distance.
    Robodoc
  • Reintz
    20
    122
    • August 27, 2024 at 5:32 AM
    Wire feed speed must be set very low for this to even remotely work, otherwise by the time it stops feeding the wire it is already pushed hard against the surface and when the robot moves away from that position the wire under tension moves further out resulting in more stick out. I've tried this method ages ago, it's not constant enough. Wire cutter is the way to go. If you need to have the wire cut in different lengths then you can use a variable combined with a tool frame shift in the cutter to get the desired length.
  • jarm
    263
    • September 5, 2024 at 9:05 PM
    wire brake wouldn't hurt either
    Edited 2 times, last by jarm (September 5, 2024 at 9:12 PM).
  • Joao Azevedo
    • September 9, 2024 at 1:42 PM
    Quote from Robodoc
    This is a good option, I have a cutter, but cutting all the time ends up being slow,
    the lack of brakes isn't helping me either
  • roboprof
    24
    469
    • September 9, 2024 at 7:04 PM
    Invest in a torch that has a wire brake if you can. I always recommend doing the wire cut, turning on the wire brake and then doing all your touch sensing, then turning off the brake and doing the welding. That way you are only using the wire cutter once.
  • Reintz
    20
    122
    • September 9, 2024 at 7:57 PM
    Interesting. I'm using a lot of wire searches and only cut it once before the searches. Never used a wire brake. Why would one need to cut the wire multiple times when not using wire brake?
    If it's because the stick-out changes too much during searching then using a step thinner spiral liner than the wire calls for helps a lot.
  • roboprof
    24
    469
    • September 10, 2024 at 3:17 PM
    The wire brake guarantees that the wire does not move when the robot is going from one touch sense location to another. Older systems did not have a wire brake but newer systems usually use it to give more accuracy.
  • Touch Sensing
  • stick-out
