CRMA15 I/O connections
  • ansul
  • August 22, 2024 at 8:32 AM
  • ansul
    Dear Experts,
    I hope you’re all doing well. I have a question that might seem basic to some, but your expertise would be invaluable to me.
    Could you kindly explain how to turn on any DI in fanuc robots? Specifically, in the CRMA15 plug, if I short DI101 to the COM pin, will it show as ON in the teaching pendant? Or do I need to supply 24V DC power to DI101? If so, where should I connect the other terminal from the 24V DC power source?
    Are there any particular settings or configurations I need to adjust?
    I plan to actuate group inputs (GI) using multiple DI pins. What configuration changes would be necessary for this? (I have configured the GI and verified its value is changing on changing the DIs value. But do we need to change some system variables or any other settings in the teaching pendant, so that it detect the physical actuation of the DI pins.)
    Your guidance on this would be greatly appreciated.
    Edited once, last by ansul (August 23, 2024 at 8:28 AM).
  • ASUA1
    24
    • September 20, 2024 at 12:06 AM
    Youll need to make sure that you properly configure the IO (RACK, SLOT, and so on).
    In order to properly set the CRMA15 IO you will need to first determine if you want sinking or sourcing inputs and then set up the SDICOM to match. Depending on what you use you will use 24F or 0V as the common.
    If you see that the GI is working when you actuate the DI then you are set to go. the GI will update whenever the DI changes.
  • hermann
    412
    2,624
    • September 20, 2024 at 8:21 AM
    For connecting the crma15 plug you should have a look into the manual (think it's the maintenance manual for your controller). There are complete schematics for connecting CRMA15.
Similar Threads
  • Connector Type for CRMA15 and CRMA16 Peripheral I/O Connectors
    • Nkohl
    • February 9, 2023 at 4:42 PM
    • Fanuc Robot Forum
  • FANUC R-30iB Mate - I/O setup and wiring
    • ven
    • November 18, 2021 at 3:14 PM
    • Fanuc Robot Forum
  • Teach Pendent
  • analog output
  • Digital IO
  • Teach pendants
  • Speed Value
  • Analog Input
  • CRMA 15
  • speed control function
  • CRMA 16
  • Digital I/O
  • I/o parameters
  • I/O mapping
  • I/O help
  • CRMA15
  • CRMA16
  • i/o module
  • teach speed
