Hello, can someone tell me how I could limit axis 1 so that when it reaches a limit it automatically stops to my kuka krc2 ed5.
How to limit axis 1 KUKA KRC2 ED5
Uros Marinkovic -
August 18, 2024 at 3:10 PM -
You can lookup $Axworkspace[] inside $machine.dat. Details can also be found in documentation and using the forum search.
PostRE: Changing the Axis Limit to prevent collision
Simply use forum search with keywords $WORKSPACE or $AX_WORKSPACE. You will find a lot of posts dealing with this.
But beware $WORKSPACE/$AX_WORKSPACE is not allowed for human safety. If safe interaction with humans is required you need SafeOperation.
In KSS 8.5.6 you find this on menu>configuration>miscellaneous
FubiniFubiniNovember 11, 2021 at 6:42 AM PostRE: Workspaces
STATE allows activation an deactivation of the workspace on the fly. E.g. inside your program.
Signals are if I remember correctly predefined. I can not look it up right now but I think they were called $AX_WORKSPACESTATE1 or something quite similar. You need to assign a $OUT[x] channel to them. Could be defined either in STEU/$machine.dat or $custom.dat if not directly in R1/$machine.dat. At least one of these 3 files should be the one. Something quite in the back of my head tries to tell me…FubiniMarch 23, 2022 at 12:20 PM Fubini
$SOFTP_END[1] and $SOFTN_END[1]
You can limit it by software end switches, which you find in maschine.dat
