Problem with high speed at the beginning of the program
  • Uros Marinkovic
  • August 17, 2024 at 1:13 AM
  • Uros Marinkovic
    38
    Hello, SPRUTCAM wrote me a code that is excellent only at the beginning of the code when the robot starts in its first PTP line and until it reaches the first LIN line it goes very fast even though I reduced its program reading speed to 60% the other code speeds are good only the one at the beginning is very fast. Can someone help me how to solve this problem so that the robot creates the first PTP line more slowly. It is a KUKA krc2 ed.5 robot. Greetings
  • Fubini
    278
    1,889
    • August 17, 2024 at 5:29 AM
    Can you share the program?
    Fubini
  • Uros Marinkovic
    38
    • August 17, 2024 at 8:52 AM
    &ACCESS RVP
    DEF ledjawoodside()
    GLOBAL INTERRUPT DECL 3 WHEN $STOPMESS==TRUE DO IR_STOPM ( )
    INTERRUPT ON 3
    BAS (#INITMOV,0)
    $BASE=BASE_DATA[2]
    $TOOL=TOOL_DATA[12]
    $VEL.CP=0.1
    PTP {A1 0.000, A2 -141.200, A3 104.850, A4 0.000, A5 35.980, A6 0.000, E1 0, E2 0, E3 0, E4 0, E5 0, E6 0}
    PTP {A1 -43.772, A2 -49.546, A3 124.491, A4 125.918, A5 76.001, A6 87.035, E1 0, E2 0, E3 0, E4 0, E5 0, E6 0}
    PTP {A1 -44.862, A2 -48.075, A3 129.605, A4 135.600, A5 82.227, A6 93.447, E1 0, E2 0, E3 0, E4 0, E5 0, E6 0}
    PTP {A1 -43.862, A2 -48.075, A3 129.605, A4 135.600, A5 82.227, A6 93.447, E1 0, E2 0, E3 0, E4 0, E5 0, E6 0}
    LIN {X 31.364, Y 303.187, Z -206.469, A 179.951, B -1.691, C -92.47} C_DIS
    LIN {X 31.28, Y 263.824, Z -208.167, A 179.951, B -1.691, C -92.47}
    $VEL.CP=0.083
    LIN {X 31.248, Y 248.814, Z -208.814, A 179.951, B -1.691, C -92.47}
    $VEL.CP=0.25
    LIN {X 66.25, Y 278.234, Z 12.931, A 174.893, B 5.091, C -135.21} C_DIS
    LIN {X 66.251, Y 223.18, Z -42.091, A 174.893, B 5.091, C -135.21} C_DIS
    LIN {X 66.251, Y 195.312, Z -69.943, A 174.893, B 5.091, C -135.21}
    $VEL.CP=0.083
    LIN {X 66.252, Y 185.639, Z -79.61, A 174.893, B 5.091, C -135.21}
    CIRC {X 1184.841, Y 0.003, Z -1.005, A -123.867, B 0.096, C -179.729},{X 1184.929, Y 0.578, Z -1.008, A -123.546, B -0.493, C -179.377} C_DIS
    LIN {X 1185.053, Y 0.811, Z -1.011, A -123.484, B -0.668, C -179.402} C_DIS
    LIN {X 1185.219, Y 1.015, Z -1.014, A -123.423, B -0.843, C -179.428} C_DIS
    LIN {X 1185.447, Y 1.218, Z -1.017, A -123.488, B -0.999, C -179.927} C_DIS
    LIN {X 1185.675, Y 1.421, Z -1.02, A -123.295, B -1.166, C -179.42} C_DIS
    LIN {X 1185.696, Y 1.602, Z 6.978, A -123.295, B -1.166, C -179.42} C_DIS
    $VEL.CP=0.167
    LIN {X 1185.842, Y 2.821, Z 60.995, A -123.295, B -1.166, C -179.42} C_DIS
    LIN {X 1186.113, Y 5.079, Z 160.995, A -123.295, B -1.166, C -179.42} C_DIS
    END
  • Uros Marinkovic
    38
    • August 17, 2024 at 8:55 AM
    Here I sent you the beginning and the end of the code, I thought you didn't need the whole code, if so, tell me. the problem occurs to me on the first three PTP lines where the robot goes very fast, and then when the first LIN lines start, the speed is good
  • Fubini
    278
    1,889
    • August 17, 2024 at 9:03 AM
    Quote from Uros Marinkovic
    BAS (#INITMOV,0)
    initialises the ptp velocity to 100 percent meaning as fast as physically possible. On the other hand lin velocity is set to 0.1 m/s by setting $vel.cp. You can set ptp velocity as well by using
    $vel_axis[<axis_index>] = <desired percentage value>
    So for axis 1 and 10 percent of maximal axis velocity for example
    $vel_axis[1]=10
    Fubini
  • Uros Marinkovic
    38
    • August 17, 2024 at 9:17 AM
    Should I insert $VEL_AXIS[1]=10 and so on for each axis before the first PTP line for example
    ACCESS RVP
    DEF ledjawoodside()
    INTERRUPT ON 3
    BAS (#INITMOV,0)
    $BASE=BASE_DATA[2]
    $TOOL=TOOL_DATA[12]
    $VEL_AXIS[1]=10
    $VEL_AXIS[2]=10
    $VEL_AXIS[3]=10
    $VEL_AXIS[4]=10
    $VEL_AXIS[5]=10
    $VEL_AXIS[6]=10
  • Fubini
    278
    1,889
    • August 17, 2024 at 9:28 AM
    Yes or whatever percentage value between 1 and 100 you like.
    Fubini
  • panic mode
    1,280
    13,086
    • August 17, 2024 at 2:12 PM
    Just use one line like
    BAS(#vel_ptp,5)
    To set ptp velocity to 5% for eample
  • Uros Marinkovic
    38
    • August 17, 2024 at 4:23 PM
    Thanks a lot for the helpful tips, I was able to solve the problem. thank you very much
Similar Threads
  • Different brake reactions when searching for one part
    • robotecnik
    • September 23, 2020 at 10:12 AM
    • KUKA Robot Forum
