We have a R-2000iB-210F robot with a R-30iA controller, Handling Tool v7.70p/53. I had no experience with robots prior to messing about with this one. We use it as a router to trim vac formed parts. The cut quality is not what I would expect and consider it unacceptable for most of our parts. Whenever the robot moves there is a little bobble--a small skip up (and it does seem to be upwards not down)-- immediately preceding a move but none at the end of a move. It does this when in teach mode or auto, when cutting or not, when moving slow or fast, using FINE or CNT motions, across various cutting planes, etc.
I attached photos of a couple cut outs showing the wonky corners to illustrate the issue. This is just an example as cutting other materials and shapes shows similar behavior, as does any motion without physically cutting anything. In this example the geometry being cut is a rectangle with sharp corners and the points were inputted mathematically using the teach pendant with all axes the same except for the X and Y, with FINE motion for all points. The part being cut is black ABS plastic 5mm thick, the fixture is tooling board foam with vac hold down (previous cut paths are visible), bit is a 1/4" dia, rectangle measures about 71mm x 108mm.
Is this behavior typical of these large payload material handling robots like something inherent in how they are geared? Or is it a mechanical or programming issue? We bought this machine used from a broker last year, the OG integrator (Robotworx) who refurbished it and designed the cell is no longer in business, and we have no support from Fanuc as it isn't licensed.
thank you for any insight you can provide!
