Kuka KRC1 devicenet not working
  • Rikkoman
  • August 10, 2024 at 1:07 PM
  • Rikkoman
    14
    im struggling to communicate with my BK5200 bus coupler and MFC on krc1..
    I got it working 2 days ago after some cussing and trying again, realized eventually that one connection was too loose and the CAN-L cable was hanging out. Also I adjusted the iosys.ini syntax which worked.
    Then decided to move and mount the modules and some I/O more neatly on a board and now the communication stopped working.
    green light on MS connect is on, I/O error and OVERFLOW blinking red
    Perhaps it has something to do with wiring, I measured CAN-L and CAN-H 2.6V with respect to ground. Also I used a ethernet cable as these wires are twisted. I fastened it with tay-rip, could it be that I damaged the cable?, I measure 0.6 Ohm of 1.5 meter cable.
    Also across CAN-L and CAN-H I measure 60ohm on cable both ends.
    Any help is much appreciated!
    Telnet dnWho response:
    Iosys.ini:
    DEVNET=2,dnInit,dn2drv.o
    [DEVNET]
    INB10=5,0
    OUTB10=5,0
    devnet.ini:
    [krc]
    debug=0
    buadrate=500
    LOGFILE=1
    [1]
    macid=5
    Edited once, last by Rikkoman (August 11, 2024 at 7:41 AM).
  • Rikkoman
    14
  • Rikkoman
    14
    • August 10, 2024 at 1:08 PM
    SkyeFire
    1,059
    9,450
    • August 12, 2024 at 3:07 PM
    The dnWho is finding the device (MAC 5), so it's not a communication issue. It's a config issue. The Beckhoff modules rely on the I/O "slices" to be in certain orders. So probably this:
    Quote from Rikkoman
    Changed the order or number of Input and Output bytes the BK is reporting to the KRC. Try a dnShow command and see what the module reports back.
  • Rikkoman
    14
    • August 14, 2024 at 10:20 AM
    Ok thanks for response,
    I read in beckhoff doc about the blinking err code I had:
    I have 4 pulses and as argument (second sequence) 1 pulse, meaning second module(0 is first)?
    Im not sure what break behind terminal means.
    (bk52x0en.pdf)
    Thanks very much, your answer helped, I played around a bit with removing I/O modules and adding, it works fine now.
Similar Threads
  • Kuka KRC2 MFC3 card driver
    • soundwawe
    • May 6, 2022 at 3:33 PM
    • KUKA Robot Forum
  • krc1
  • DeviceNET
