  4. ABB Robot Forum
ABB Integration Vision Rapid code issue
  • H.CHOI
  • August 8, 2024 at 11:11 PM
  • H.CHOI
    35
    Hi everyone,
    I posted ABB integration vision issue a week ago and got a lot of support here. I really appreciate it all
    Just have another question about the rapid code here.
    Basically, we have 2 different job one is LH job and the other one is RH job all vision inspection jobs. If you look at the attached if statement,
    If camjob and tempjob is not equal, we load the job otherwise (I guess same job) we don't load the job and just go to runmode.
    Our sequence is LH job inspection -> RH job inspection -> another RH job inspection
    so after robot loads RH job, we don't need to load same RH job for 3rd inspection.
    so instead of calling Camloadjob, it should go to Camsetrunmode right away
    but somehow robot keep loading the job evenif it is the same job
    Is my if statement wrong?? or any other method to make it work?
    Images
      • 12.39 kB
      • 460 × 306
      • 13
  • Go to Best Answer
  • Lemster68
    301
    2,493
    Blog Articles
    7
    • August 9, 2024 at 5:31 PM
    Does this happen to be in a NOSTEPIN module? I would suggest if not, then you could single step through it so you could examine and compare the values yourself before the rapid code is executed. That might give you some insight as to what is going on. If it is NOSTEPIN, you could remove that attribute and do as I suggest.
  • bull_boxer454
    7
    14
    • August 9, 2024 at 5:44 PM
    The CamGetLoadedJob function can leave the .job suffix in the string it returns. This will make the <> comparison not match. For example, the string "camjob" does not match a string of "camjob.job". For testing, you can use a TPWrite instruction to show each of the two variables before during testing and make sure the strings are in the same format.
  • ColoradoTaco
    16
    103
    • August 9, 2024 at 6:17 PM
    Quote from bull_boxer454
    I discovered the exact same thing recently. Here's the routine I'm running in a no-stepin.
    H.CHOI Notice that the string pulled by CamGetLoadedJob does NOT include the .job suffix. I add that to the comparative IF statement to check if the requested job matches.
        PROC LoadVisionJob(string JobName)
            VAR string currentjob;
            currentjob:=CamGetLoadedJob(Cognex_8402);
            TPWrite "Current Cam Job: "+currentjob;
            IF currentjob=JobName+".job" THEN
                TPWrite "Current Job matches Requested Job.";
                RETURN ;
            ELSE
                CamFlush Cognex_8402;
                CamSetProgramMode Cognex_8402;
                TPWrite "Camera set to Program Mode";
                CamLoadJob Cognex_8402,JobName;
                TPWrite "Loaded Camera Job: "+JobName;
                CamSetRunMode Cognex_8402;
                TPWrite "Camera set to Run Mode";
            ENDIF
            RETURN ;
        ENDPROC
  • H.CHOI
    35
    • August 9, 2024 at 7:38 PM
    Lemster68  bull_boxer454  ColoradoTaco
    Thank you so much for reply guys.
    Since I am very new to ABB rapid code and this whole script was written by integration company and they don't exist anymore.
    I noticed our original code has commented out "Camgetloadejob" so it actually did nothing.
    if you guys look at the main program, I wanted to run 3 lines
    GetCameraData_LH
    GetCameraData RH
    GetCameraData RH
    in this sequence, RH runs twice so our <> statement should work??
    I attatched GetCameraData_LH (RH is the same but different job name) here as well.
    It will go to InitCam(attached previous message) and read the lines.
    I skipped all Camera error or Camera requirement because we don't have part here.
    When I run in manual mode with flexPendant,
    Line went through CamSetprogrammode->Camloadjob->Camsetrunmode
    and it repeated this sequence 3rd time even if 2nd and 3rd job has the same name
    Is there anything I missed or code issue here?
    Again, thank you so much
    Images
      • 4.56 kB
      • 430 × 71
      • 2
      • 6.41 kB
      • 485 × 143
      • 2
  • ColoradoTaco
    16
    103
    • August 9, 2024 at 7:51 PM
    I'm curious to see if you are either dropping or retaining the job name suffix. Also, the GetCamLoadedJob can take a second to process. Sometimes it helps to add just a tiny delay to allow registers to get updated.
    Try this after your GetCamLoadedJob instruction:
    WaitTime 0.1;
    TPWrite "Camjob:  "+CamJob;
    TPWrite "TempJob: "+TempJob;
    Stop;
    If those two lines don't print out exactly the same on the pendant, you'll have your answer.
  • H.CHOI
    35
    • August 9, 2024 at 8:37 PM
    Quote from ColoradoTaco
    WaitTime 0.1;
    Stop;
    Thank you ColoradoTaco
    I did what you posted here
    Our inspection sequence: LH->RH->RH so after cycle is done, tempjob should be RH
    1st inspection
    camjob: EnvPanelLHEdge0208
    tempjob: EnvPanelRHEdge0208.job
    so it loaded the job
    2nd inspection
    camjob: EnvPanelRHEdge0208
    tempjob: EnvPanelLHEdge0208.job
    3rd inspection
    camjob:EnvPanelRHEdge0208
    tempjob:EnvPanelRHEdge0208.job
    So 3rd inspection, it is same job name but it loaded job again
    Is it because of .job at the end of tempjob? like other guys mentioned above?
    If so, how to remove that .job?
    right now i have
    tempjob:=CamGetLoadedJob(Envelope_Camera);
    and camgetloadedjob and envelope_camera are blue colored
  • Lemster68
    301
    2,493
    Blog Articles
    7
    • August 9, 2024 at 8:54 PM
    Yes, that is what is going on, they don't match. It was suggested that you add the .job to what you are comparing so they do match, not remove the .job from the other.
  • H.CHOI
    35
    • August 9, 2024 at 9:07 PM
    Quote from Lemster68
    Thank you Lemster68
    should I add .job right next to the string camjob? like string camjob.job? it gives me an error
    sorry about stupid question
  • ColoradoTaco
    16
    103
    • August 9, 2024 at 9:18 PM
    • Best Answer
    H.CHOI it is a LOT easier to add characters to a text string than to parse them out of an existing string.
    You can do it like this in your IF statement
    For comparison, here is the vision load routine I run. It checks the existing job first, and only loads if the requested job is different.
                RETURN ;
            ELSE
            ENDIF
            RETURN ;
        ENDPROC
  • H.CHOI August 9, 2024 at 11:43 PM
    Selected a post as the best answer.
  • H.CHOI
    35
    • August 9, 2024 at 11:44 PM
    • #11
                RETURN ;
            ELSE
            ENDIF
            RETURN ;
        ENDPROC
    Thanks everyone ColoradoTaco  bull_boxer454  Lemster68
    it is matching and robot skip the loading the job between 2nd and 3rd inspection
