Good afternoon, tell me how to solve this problem.
LNTK-026 encoder not enablet
ANRB -
August 8, 2024 at 2:18 PM -
You could help us to help you by posting this in the correct robot sub forum. What robot brand and what version of controller?
Fanuc p-40ia robot
Fanuc r-30ib mate plus controller
For painting
SkyeFire
August 8, 2024 at 3:13 PM Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum. -
Line 4 of Main. You might want to try switching that "OFF" to an "ON".
Thanks, I've already turned it on, but I can't synchronize the speed of the robot with the speed of the conveyor, the robot moves the same way when the conveyor is turned on and off.
How can I solve this problem, this is my first time working with encoder
You posted a fault code, the problem was identified, a solution was provided, but the fault code is not your issue?
Maybe Nation can assist? -
Sounds like your scaling factor is off. What is defined in your tracking schedule? Did you go through the tracking setup? Is the direction defined?
Also, I'm not as familer with paint robots, but the tracking should be similar.
