Hi.
I'm trying to revive a KR 15 L16/2 KRC1 KSS 2.3 with no documentation or electrical schematics, so I'm a bit lost.
I'm having a problem with the Fronius solding station, when I turn on the station, it keeps feeding wire nonstop, so I'm trying to diagnosticate the problem.
Starting from a possible software problem, I took a look at the IOSYS.INI file and found something concerning, I'm attaching the file in txt.
As you can see, the DeviceNet, the one that goes to the Fronius station, is ocupying the bits 1 to 32.
The PROFISL is also located there, so I don't know if that can be an issue.
I also took a look at the config file and found multiple signals declarations in the ArcTech technologies in the same adress, I'm concernt about that too.
After confirming if there's any problem in the software, I'll go and take a look at the Fronius station, but I want to make sure that there's no dumb error here with an easy fix.
Also, there are many other signals without maping, I'm still trying to map everything, this cell is a chaos, but I think I got enough for now.
Thanks in advance.
