Restoring backup
  • edimmy
  • August 1, 2024 at 9:10 PM
  • edimmy
    19
    I don't have a ton of fanuc experience, so bear with me.
    Recently, I tried to upload from roboguide to my SR-6iA with a R-30iB Plus controller. I followed this ( https://www.youtube.com/watch?v=t88ivw7T7hU ) tutorial, and used a USB with the following files uploaded:
    • DIOCFGV.IO
    • NUMREG.VR
    • POSREG.VR
    • SYSFRAME.SV
    • FRAMEVAR.VR
    • a .TP file
    I did a controlled start of the robot, plugged the USB in, and set the device to the USB in the TP in the File menu. When I went to load the files, I was pretty sure it worked, but then I couldn't do a cold start as was advised in the tutorial. I kept getting a pop up saying "SW Install Requires AutoUpdate", but then when I tried running the AUTOUPDT.CM file the TP would freeze.
    Today, in an attempt to just revert everything back to how it was before I tried to upload from roboguide, I plugged in the USB that came with the robot with the software loaded on it. I did a "full software install" from the boot screen, picked "previous profile" or something along those lines (the other option was SR-6iA [...] but I didn't know which one to pick), plugged in my USB with a backup, and tried to restore but got the message "directory is not processed". I was under "all files" in the folder that had the backup I wanted to use, but I just couldn't get it to load.
    Any advice? I've been reading a little bit about mastering and have a feeling I messed something up by not moving the robot to a home position (?) before doing all of this. I just want it to go back to how it was:loudly_crying_face: as always, any help would be greatly appreciated.
  • HawkME
    568
    3,268
    • August 2, 2024 at 1:08 AM
    Do you have an image backup? That is the first step after installing software and before making any major changes. If so simply restore the image. If not then I usually use FTP to send all files to the robot while in a ctrl start.
  • n8z
    8
    • August 7, 2024 at 11:20 PM
    Did you load the backdate.dt file from your robot into your Roboguide cell when you were creating the project? If not it is possible that you have a newer version of Roboguide than what your physical robot has.
    If you try and load the backdate.dt file from your robot into your Roboguide's current workcell and re-serialize the Roboguide robot does it give you a version error?
  • Erik Olsen
    53
    5
    176
    • August 7, 2024 at 11:38 PM
    Quote from edimmy
    Do not select the previous profile; select SR-6iA. Not sure if that's your whole problem but the software install quick start guide is pretty insistent that select the profile that matches your robot model.
Similar Threads
  • Not following path correctly
    • JordanLove
    • March 7, 2024 at 7:09 PM
    • Fanuc Robot Forum
  • Backup & Restore robot position best practices
    • asdf
    • September 14, 2023 at 3:42 PM
    • Fanuc Robot Forum
  • KCP is frozen after start up ...
    • bakerhesseldenz
    • September 11, 2023 at 11:41 PM
    • KUKA Robot Forum
  • Error kuka etcherCAT missing packed and more
    • Lemoor
    • March 21, 2023 at 7:26 PM
    • KUKA Robot Forum
  • Programming a back up robot for just in case includes dcs (fanuc)
    • Roborob$
    • April 20, 2023 at 3:34 PM
    • Fanuc Robot Forum
  • EtherCAT timeout / No connection to KRC
    • rydeck
    • August 11, 2020 at 8:29 PM
    • KUKA Robot Forum
  • How to Restore from a *.zip Archive file on a USB
    • C4Boom
    • March 6, 2022 at 6:12 PM
    • KUKA Robot Forum
  • FROM and SRAM backup files from IMAGE
    • vrehere
    • June 22, 2021 at 6:52 PM
    • Fanuc Robot Forum
  • restoring a backup in a r2000ic and it wont let me load all the files
    • Volic82
    • May 19, 2021 at 11:03 PM
    • Fanuc Robot Forum
  • Restore System/Config: From which file in backup?
    • GeorgeTheThird
    • May 18, 2021 at 2:27 PM
    • Fanuc Robot Forum
  • Restore
  • load
  • image
  • directory
