hi all, I would stop a movej function with until SRCH command connecting the button in RIN#(1)
where I had to connect the button in the DX200 controller? I need add some command in the ladder?
many thanks
many thanks
The software option needs to be turned on by Yaskawa. The RIN sensor gets hooked up to a mini breakout board (YFC22E) that has a cable running to the machine safety board (YSF22) and on the EAXA board.
RIN 1 is pins 84 and 86.
I found how to connect and in the input RIN I can see when the RIN#(1) turn on
I set movej in order to stop with input but it not stop. I think that dx200 which I have, is aready available for RIN input
why robot not stop movement movej movement?
Is it even possible to use RIN with MOVJ? I've only seen the RIN extension on MOVL, though I've had situations where I needed to use it with MOVJ.
You need to use the SEARCH command. This is the only command that will stop the robot with a RIN. The search command is a purchased option from Yaskawa.
The SRCH is on the MOVL and IMOV instructions.
